make motor go slower
how do you make you motor go slower
Re: make motor go slower
If It's on a speed controller you can control the speed with a PWM signal. This will also decrease the torque on the motor.
If it's on a relay you're pretty much stuck with one speed. You can make a motor go slower with a gear/sprocket/belt reduction as well. |
| White Paper Discuss: Approx. Motor Spec for Taigene Motor | Joe Johnson | Motors | 2 | 22-01-2005 16:36 |
| Is it okay to run one motor in a two motor transmission? | NoodleKnight | Technical Discussion | 27 | 16-12-2004 07:16 |
| External metal jacket on the Drill motor and FP motor, WHY? | archiver | 2001 | 3 | 24-06-2002 04:22 |
| External metal jacket on the Drill motor and FP motor, WHY? | Dennis Hughes | Technical Discussion | 1 | 04-06-2001 11:59 |
