Go to Post ...and that is exactly why Dave is the coolest nerd I know. - Rich Kressly [more]
Unread 19-02-2007, 09:41
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: batteries on the controler
If you are asking whether you can use external power sources (batteries, AC Adapter...) on the OI during a match, the answer is NO, with the exception of the USB Chicklets.
Unread 19-02-2007, 09:49
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
If you're asking whether you can use batteries to power up the controller for a demo, etc. Then yes you can if you get a plug to connect the batteries to the power port. Just make sure the batteries are the right voltage and you have the polarity correct.
Unread 19-02-2007, 10:49
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Yes to what Kevin said, and to add that you do not need to worry about the plug at competitions, since the OI gets its power from the competition port.
Ricky Quinones
Director of Sales - VEX Robotics
Unread 25-02-2007, 00:48
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
But what if the battery system never touches any OI pins, and are simply used to power devices on board the OI (like lights and fans and stuff)
I'm pretty sure this is legal.
Jacob
Unread 25-02-2007, 11:23
Right, though the only OI pins you need to worry about are the joystick connectors. A battery-powered device on the dashboard port is explicitly permitted (and the tether, radio, and competition OI ports are totally off limits).
Unread 25-02-2007, 11:43
To be more specific, power for a computing device connected to the dashboard port and power for a chicklet are the only things allowed to be externally powered. Any external power for devices connected to the OI (LEDs, lamps, relays, etc.) are strictly prohibited. Joysticks, pots, switches and LEDs can be connected to the OI only when they receive power from the OI ports. See the OI reference manual for details.
From Page 24 of the Robot Rules
<R83> All equipment connected to the joystick ports of the Operator Interface must be powered
solely through the power available through the port. External power sources of any type are
not permitted on any equipment connected to the joystick ports. Portable computing
devices can not be connected to joystick input ports on the Operator Interface. Powerpassive
devices (e.g. joysticks that draw their power solely through the Operator Interface
joystick port) are permitted. The one exception to this rule is Innovation First Incorporated
USB adapters (IFI Part Number USB-CHICKLET) may be used to connect USB devices to
the joystick ports of the Operator Interface. If used, this USB adapter must be powered with
a 7.2V battery similar to the back-up battery. Teams can not use power from the
competition port or any other source to power the USB adapter. The USB adapter must be
positioned within the OPERATOR CONSOLE so that the indicator lights may be seen during
inspection and operation in a match.
YMTC: The Twelve Batteries of Christmas Natchez General Forum 5 04-02-2007 14:44
timer in the robot controler MaCaBi Programming 2 06-02-2006 13:55
Using a USB Controler Ethulin Control System 8 27-01-2006 21:46
Charging the 7.2 Volt Batteries roboticsguy1988 Control System 43 17-01-2006 20:59
Visible Controler Interface m0rph3us Control System 3 08-02-2004 14:28
