#8
Re: Capacitor Question
Allow me to clarify my previous post.
I meant 5 meters/second, not 5 milliseconds. My weight budget is theoretically unlimited as long as the final machine fits into a 30cm x 30cm x 60cm box. The motor voltage is somewhere in the neighborhood of 3volts. So, a final output voltage from the capacitor of 6volts should be doable. The amperage as well. 9A discharge from the supercap that I would like to use should be more than enough. Choosing the capacitor isn't too much of a problem for me, unless the supercap battery link I posted earlier has some property which I am not aware of. You're right, the motor is nowhere near 100% efficiency, but neither are my competitor's motors (we all use the same one). So for comparison purposes, I think I'm fine. So far Al, you have provided me a wealth of information. Thank you for that. However, I need to design a circuit which performs as follows:
I have very little experience designing these kind of circuits, and that is where I need help. The supercapacitor's properties seem to be sufficient to provide just the power I need in order to get the car to jump out of the starting gate, and then pretty much coast to the finish line. I hope my intentions are clearer. |
| Servo behavior question / advanced servo/PIC programming question | DanL | Electrical | 12 | 18-10-2005 18:33 |
| pic: 610 Flux Capacitor (after teaser 2) | The_Goodie | Robot Showcase | 10 | 04-02-2005 22:23 |
