Go to Post But should we "discriminate" based on how long your team has been around? If you think about it, FIRST's goal is to inspire students, right? ...But students on rookie and second-year teams, if anything, are in greater need of being inspired. - LauraN [more]
Unread 19-02-2007, 10:19
Billfred's Avatar
Billfred Billfred is online now
Attaching Denso motor adapter to the motor?
So, with one day before ship, we're getting started on our end effector. (C'mon, we're only a little bit behind...)
We've identified the Denso motor as a good match with what we want it to do, but we've hit a snag: we're not quite sure what's the best way to attach the adapter that came in the KOP to the motor's shaft. What would seem to work is to poke a hole concentric with the output shaft, then put a screw in that's large enough to keep the adapter engaged, but IANAME.
Is there some practice I'm just missing out on by searching "denso motor adapter"?
2 motor adapter and keyang motor dimensions Bruno Estevão General Forum 1 16-02-2007 09:36
Need a Denso Motor Vegas Motors 1 09-02-2007 22:38
Coupler for Denso Motor nlknauss General Forum 1 05-02-2007 17:20
How to get Nippon-Denso Motor walterj Motors 2 05-02-2004 07:20
Nippon Denso Window Motor Specs RichardBCR Motors 13 26-01-2003 07:01
