Go to Post Ancient doesn't necessarily mean bad, but ancient things do fall out of use, otherwise I'd be tapping this out in morse code or writing it in Latin. - Greg McKaskle [more]
Unread 19-02-2007, 10:24
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Re: Attaching Denso motor adapter to the motor?
Hi Billfred,
One thing to keep in mind here is that the metal shaft sticking out the center of the plastic splined piece of the denso motor does not rotate, it is fixed. The plastic gear and splined bit rotate around the metal shaft like a dead axle. If you put a screw in the end like you are proposing, it may be subject to unscrewing itself with normal operation of the motor.
I am not sure of your setup, but in many cases I have seen the Denso motor used with the long keyed portion of the plastic KOP adapter removed. If you are doing this then you could probably groove the end of the fixed metal shaft and put a snap ring on it. If you have little pride (like us) you can make this groove with a little care using a bandsaw or a hacksaw.
Good luck,
RAZ
2 motor adapter and keyang motor dimensions Bruno Estevão General Forum 1 16-02-2007 09:36
Need a Denso Motor Vegas Motors 1 09-02-2007 22:38
Coupler for Denso Motor nlknauss General Forum 1 05-02-2007 17:20
How to get Nippon-Denso Motor walterj Motors 2 05-02-2004 07:20
Nippon Denso Window Motor Specs RichardBCR Motors 13 26-01-2003 07:01
