Go to Post make sure you are having fun and developing yourself, not just learning - gixxy [more]
Unread 19-02-2007, 11:01
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Emergency
<R16> ROBOTS must use the diagnostic signal LED provided in the Kit Of Parts. Field personnel
will use the LED during the matches for diagnostic purposes. It must be mounted on the
ROBOT such that it is easily visible while standing three feet in front of the ROBOT in its’
STARTING CONFIGURATION.
Instructions for connecting the LED are provided on the
FIRST website at www.usfirst.org/frc/2007/manual The Robot Controller directly powers
and controls the LED. The user has no control over the LED and no programming is
required.
It's pretty bright, so as long as you don't bury it inside the robot, you should be fine.
<R79> Teams are permitted to connect a portable computing device (Laptop computer, PDAs, etc.)
to the RS232 Output of the dashboard port of the Operator Interface for the purpose of
displaying feedback from the ROBOT while participating in competition matches. Please
note that AC power will not be available at the playing field so these devices will have
to run on internal batteries.
emergency sanding question brennerator General Forum 6 21-03-2006 21:51
GUYS EMERGENCY VEN General Forum 5 04-04-2005 16:50
worm gear emergency ClicheCow Technical Discussion 5 21-02-2005 01:39
VIZ Emergency Jeremiah Johnson Inventor 4 22-01-2005 19:55
Drill Motor Emergency OZ_341 General Forum 10 15-02-2004 03:33
