Go to Post Ken Patton rocks my socks off! - Josh Hambright [more]
Unread 18-02-2007, 22:37
lkdjm's Avatar
lkdjm lkdjm is offline
AKA: David Mazza
FRC #0564 (Digital Impact)
lkdjm will become famous soon enough
Send a message via AIM to lkdjm Send a message via Yahoo to lkdjm
HELP NEEDED! Camera twitches while disabled
Our camera's pan servo motor twitches to the right (looking at the front view of camera) while the robot is disabled or "killed". Everything else works fine (so far) but the twitching is killing the servo. The tilt servo motor is fine. Like I said, the camera has no problem in normal or autonomous mode. It tracks and finds the light perfectly. We are concerned that this will happen before and after every match while the bots are disabled. This will soon kill our pan servo motor. Any and all help is GREATLY APPRECIATED!
Longwood's Digital Impact
Unread 18-02-2007, 23:09
David Doerr's Avatar
David Doerr David Doerr is offline
FRC #4478 (Materia Oscura)
David Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud of
Re: HELP NEEDED! Camera twitches while disabled
Our camera was doing exactly that. I found the camera would quiet down and behave normally (steady at neutral pan and tilt) by bypassing our installed camera servo pwm wiring. I suspect electrical noise induced in the idle pwm circuits while in disable mode - possibly from the camera's TTL serial wiring.
Unread 18-02-2007, 23:49
David's right. It's crosstalk from the camera serial data being interpreted as pwm signals by the servo. I saw several cameras including ours at competition last year "nodding" while they were disabled, often seemingly in time with the music being played.
With the servo and camera data wiring separated, the problem goes away.
Unread 19-02-2007, 07:34
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
I have this problem also. Would insulated wires being together be enough to cause this interference? It seems unlikely to be but we definately have the same problem. I'd hate to mess up my pretty wiring to stretch the TTL wire away from the rest of the wires.
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 19-02-2007, 11:04
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
Do oscillations wear down the servos that quickly?
Unread 19-02-2007, 11:34
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Our camera did this as well last year, causing it to knock into a CIM motor when disabled. It was kind of loud and sounded like a woodpecker. While you can fix it by moving the wires further apart or possibly by using shielded wire for the camera serial connection, I wouldn't worry about it. Our robot did that the whole season last year and it never became an issue. The servo didn't wear out or anything.
Camera help needed bluisnake Programming 9 08-08-2006 14:58
Urgent help needed : Camera locks on to no apparent target! ?!?! Salik Syed Programming 11 06-03-2006 17:24
Emergency Help Needed on Main Board and Camera amateurrobotguy General Forum 9 09-02-2006 21:22
Moving robot while tracking with camera questions... Steve Orr Programming 6 02-02-2006 22:24
camera help needed Anton Programming 0 17-02-2005 06:52
