Go to Post "As president, I believe that robotics can inspire young people to pursue science and engineering. And I also want to keep an eye on those robots in case they try anything." — Barack Obama - Ted Weisse [more]
Unread 19-02-2007, 10:53
feliks_rosenber's Avatar
feliks_rosenber feliks_rosenber is offline
Félix
AKA: Mentor of Teams #2217 & #2669
FRC #2217 (FOMHA & KY Bots)
feliks_rosenber is a jewel in the roughfeliks_rosenber is a jewel in the roughfeliks_rosenber is a jewel in the rough
Send a message via MSN to feliks_rosenber
Question Emergency
Hello everyone !
I would like to know how and where should we connect the emergency bulb.
Second, is it possible for the human player (the one who throws the ringers) to use a computer software at the event in order to direct his drivers where to put the ringers or is it to be done by the team coach ?
Unread 19-02-2007, 11:01
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Emergency
<R16> ROBOTS must use the diagnostic signal LED provided in the Kit Of Parts. Field personnel
will use the LED during the matches for diagnostic purposes. It must be mounted on the
ROBOT such that it is easily visible while standing three feet in front of the ROBOT in its’
STARTING CONFIGURATION.
Instructions for connecting the LED are provided on the
FIRST website at www.usfirst.org/frc/2007/manual The Robot Controller directly powers
and controls the LED. The user has no control over the LED and no programming is
required.
It's pretty bright, so as long as you don't bury it inside the robot, you should be fine.
<R79> Teams are permitted to connect a portable computing device (Laptop computer, PDAs, etc.)
to the RS232 Output of the dashboard port of the Operator Interface for the purpose of
displaying feedback from the ROBOT while participating in competition matches. Please
note that AC power will not be available at the playing field so these devices will have
to run on internal batteries.
Unread 19-02-2007, 11:08
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Emergency
tdlrali,
The rule you quoted says signal LED must be visible when standing 3 feet in front of the robot in its starting configuration. This is not at all the same as being clearly visible from all sides of the robot.
In response to the original, FIRST okayed coaches using handheld computers, etc. running strategy software as long as they aren't interfering with the arena control system, communicating wirelessly with anyone, etc.
Félix
Thanks !
Only I haven't asked my second question well :
Is it possible for the human player to use the laptop or is it to be done by the coach ?
Now it's clear...
Thanks !
Sorry I have missed some rules , rookie team , you know...
Unread 19-02-2007, 11:13
Re: Emergency
Sorry for being unclear, disregard my statement about "The signal light should be clearly visible from all sides." I mixed it up with the flag rules.
About the laptop:
From Team Update #3:
Devices used solely for the purpose of planning or tracking strategy of game play are
allowed inside the ALLIANCE ZONE, if they meet ALL of the following conditions:
Do not connect or attach to the OPERATOR CONSOLE
Do not connect or attach to the FIELD or ARENA
Do not connect or attach to another alliance member
Do not communicate with anything or anyone outside of the ALLIANCE ZONE (for
example wireless communications must be disabled).
Do not in any way affect the outcome of a MATCH, other than by allowing team
members to plan or track strategy for the purposes of communication of that
strategy to other alliance members.
However, from http://forums.usfirst.org/showthread...hlight=laptop:
A laptop connected to the Dashboard Port of the Operator Interface would be considered part of the Operator Console. As such, the Coach may not touch the dashboard laptop without violating Rule <G49>.
So you can bring a laptop, PDA... However, the coach cannot use a laptop that is connected to the OI.
I couldn't find any info on the human player, however.
Unread 19-02-2007, 11:14
Re: Emergency
Here's the new rule:
<T23> The only equipment that may be brought on to the field is the OPERATOR
CONSOLE, reasonable decorative items, and special clothing and/or equipment required
due to a disability. Other items, particularly those intended to provide a competitive
advantage for the HUMAN PLAYER, are prohibited.
 Do not connect or attach to the OPERATOR CONSOLE
 Do not connect or attach to the FIELD or ARENA
 Do not connect or attach to another alliance member
 Do not communicate with anything or anyone outside of the ALLIANCE ZONE (for
 Do not in any way affect the outcome of a MATCH, other than by allowing team
It says team members, so anyone should be able to use them
Unread 19-02-2007, 11:25
Félix
Re: Emergency
Sorry but you made me confused.
So is it to be connected to the operator console or not ?
Unread 19-02-2007, 11:51
Re: Emergency
If it is connected to the OI/Dashboard port, the coach may not use it (only the drivers).
If it is not connected the the OI, the coach can use it.
However, the rule does not specify whether the human player can use a laptop, either connected to the OI or not. Since there is no rule against it, I would assume that it is allowed.
Unread 19-02-2007, 17:46
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
Re: Emergency
Based on the rules posted above, if a human player uses a laptop to communicate with the other members when the laptop is not connected to the OI, it is an "other item" that will affect the outcome of the match, so it is prohibited.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 23-02-2007, 14:02
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Emergency
I would disagree with this view. How does the human player using a laptop to track the score violate T23? As far as I can tell it does not. The way in which it affects the outcome of the match is clearly defined as permitted by T23 as it would be used to track or plan strategy in order to communicate it to alliance members.
Unread 23-02-2007, 15:26
Re: Emergency
feliks,
A better answer would be that the human player is going to be very busy during the match. As long as two mintes sounds, it goes by very quickly. I would recommend that the human player might want to advise the coach of the current score while he/she is feeding the field with tubes. I would not recommend that this person be distracted during a match. Human players when used properly can have a big impact on the strategy of the game. You are after all another set of eyes for your alliance.
emergency sanding question brennerator General Forum 6 21-03-2006 21:51
GUYS EMERGENCY VEN General Forum 5 04-04-2005 16:50
worm gear emergency ClicheCow Technical Discussion 5 21-02-2005 01:39
VIZ Emergency Jeremiah Johnson Inventor 4 22-01-2005 19:55
Drill Motor Emergency OZ_341 General Forum 10 15-02-2004 03:33
