Go to Post The competition is about MUCH more than just the robot. If kids are glued to the robot all of the time, then they miss the rest of it... the other fun stuff, what makes FIRST, FIRST. - Kims Robot [more]
Unread 19-02-2007, 12:39
Armando's Avatar
Armando Armando is offline
...I'm hungry...
AKA: Naoki
FRC #2061
Armando is an unknown quantity at this point
camera wire up
i need to know if the camera needs its own power source, or does it just connect to the robot controller.
"Is it the anime?..."
Unread 19-02-2007, 12:53
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: camera wire up
It gets power from the RC
Unread 19-02-2007, 13:00
Armando's Avatar
...I'm hungry...
AKA: Naoki
FRC #2061
Re: camera wire up
ok thanks. we didn't know and the camera is the last thing left to work on.
Unread 19-02-2007, 13:06
Re: camera wire up
Good luck!
For more info, here is on all the pins on the camera:
http://www.ifirobotics.com/docs/cmu-...a-assembly.pdf
Unread 22-02-2007, 08:59
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Re: camera wire up
It plugs into an unused PWM output on the RC which is powered by the backup battery so make sure its charged.
Amperage Robotics Team 1225
Site under-going revamp. :/
Wire Schematic Guru Electrical 1 16-02-2007 16:18
Camera Help (New to Camera Programming) Idaman323 Programming 6 14-01-2006 03:56
Ramp wire Stephen Kowski Rules/Strategy 1 05-01-2003 11:02
NUMBER 16 WIRE archiver 2000 1 23-06-2002 23:04
Shipped Wire Warren Boudreau Electrical 15 07-03-2002 21:00
