Go to Post Ive always wondered about this - if DK has an alter ego, like Clark Kent and Superman - KenWittlief [more]
Unread 19-02-2007, 18:25
354.FIRST 354.FIRST is offline
FRC #0354
354.FIRST is an unknown quantity at this point
Gear Tooth Pulse Height ??
We are trying to use our gear tooth sensor.
We can see it work on the oscilloscope but Easy C gets no reading.
The pulse on the ossiloscope is about 1.2V high.
Anyone know how strong a pulse we should expect?
-354
Visit our website at GWestRobotics.Com
Unread 25-02-2007, 08:15
Re: Gear Tooth Pulse Height ??
If you are going to a digital input (no an analog one), they typically require more than 2 V for reliable operation. If the input is typical CMOS (not TTL or TTL-compatible CMOS), the figure is 'more than half of the internal supply voltage'. I haven't taken apart a new RC, but that is probably 5 V, meaning around 2.5 volts.
Try getting the sensor closer to the tooth, or put some iron along the side of the gear to increase the magnetic field strength.
Unread 25-02-2007, 14:18
Dave K.'s Avatar
Dave K. Dave K. is offline
Engineer/Mentor
FRC #0930
Dave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to behold
Table 1-4 in the microcontroller datasheet details which pins are Schmitt trigger inputs, and which one's are TTL. Cross referencing the digital I/O definitions found in 'ifi_aliases.h' will provide the information as to which I/O pin corresponds to which pin on the CPU.
Section 28.3 of the datasheet details the minimum logic thresholds for each pin type.
Maximum Logic Low voltage:
TTL: 0.15Vdd (0.75V)
Schmitt: 0.20Vdd (1.0V)
Minimum Logic High voltage:
TTL: 0.25Vdd + 0.8V (2.05V)
Schmitt: 0.8Vdd (4.0V)
Thus, User I/O pins 1 and 2 (RB2 & RB3) would use Schmitt logic thresholds when used as interrupts. User I/O 3-6 (RB4-7) would use TTL logic thresholds for the interrupt-on-change inputs.
The other user inputs vary in type.
--Dave
Unread 26-02-2007, 07:26
As they always say, when in doubt, Read The Manual - in this case the IFI manual !
Gear Tooth Sensor Zoom Programming 46 22-01-2008 08:05
Gear Tooth Code magical hands Programming 1 19-02-2007 00:05
Gear Tooth Sensor? Raikon Kit & Additional Hardware 3 09-02-2007 16:40
24 Tooth Gear Sprocket daviamp General Forum 4 29-01-2007 00:04
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
