Go to Post You can never have enough teamwork. - Koko Ed [more]
Unread 19-02-2007, 18:25
Team 849 Team 849 is offline
FRC #0849
Team 849 is an unknown quantity at this point
ramp tractions
Are we alloud to use electrical tape or foam tape to provide traction on the RAMP?
Thanks
Unread 19-02-2007, 18:31
Aratarin Aratarin is offline
AKA: Aaron Dunk
FRC #1652 (Lakeview Legends)
Aratarin is an unknown quantity at this point
Re: ramp tractions
I don't beleive that this is allowed.... Rule <R35> States that electrical tape can only be used as an electrical insulator and it also states foam tape may only be used for attacjing components.
Sorry... We were hoping to do this same thing before, also.
Good luck!
Aratarin
Team 1652
Wisconsin Regional ROCKS!
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: ramp tractions
From my understanding, no. We got burned by this one last year. We used tape to just post our team number and sponsors. We had to remove them and find another way of posting them at the competition. We got lucky and another team gave us some glue.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 19-02-2007, 18:35
FRC #0849
Re: ramp tractions
thats a bummer, thanks anyways
Unread 19-02-2007, 18:40
Electrical Engineer
Rookie Year: 1995
Re: ramp tractions
The best FIRST legal way to provide traction on rams is to get some epoxy garage floor paint at your local hardware center. There are abrasive additives (sand) that can be added to this paint to provide a durable non-slip surface to your ramp.
Mike Betts
As easy as 355/113...
Unread 19-02-2007, 19:06
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Re: ramp tractions
Alright, lets look back a little bit. You aren't allowed to use any kind of tape or adhessive material on the robot. The question was brought up on FIRST Q&A. We were concerned with the same thing. The teacher on the team went ahead and read the Q&A about it. Someone asked if we could take the material, sand the sticky side out, and use epoxy to put it on. The response we got was positive.
Correct me if I am wrong, but I thought you could use numbers and sponsor's decal as long as it is just for decoration?
Unread 19-02-2007, 20:25
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
Re: ramp tractions
You can buy paint with grit in it. It’s used to paint onto concrete steps and other smooth surfaces. You can get it at Grainger, and maybe Home Depot/Lowes. As far as tape for numbers I think that legal as the post before me said. Its a decoration not a functional part. If that was the case then stickers with logos and numbers would not be competition legal.
Kirk
Unread 20-02-2007, 10:19
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
Re: ramp tractions
Kirk
I saw a team last night that painted their ramp with this sort of epoxy material. It contained high-grit and (looked like) a varied amount of specks that felt quite rough to the touch. The team said they were easily able to paint/prime their aluminum and it took only 24 hours to cure completely.
Unread 20-02-2007, 10:33
Molten's Avatar
AKA: Jason
Wink Re: ramp tractions
That means that they have just under the amount of time they would need. Unless, it can cure in their crate.
Unread 20-02-2007, 10:44
Stillen Stillen is offline
Stillen is just really niceStillen is just really niceStillen is just really niceStillen is just really niceStillen is just really nice
Send a message via ICQ to Stillen
Re: ramp tractions
I've read the responses over at the FIRST Q&A.... You guys need to head over there and look at some of them.... The solutions vary. Looks like one team is using those adhesive stair treads, but they are removing the factory adhesive, and then using their own adhesive, to adhere the sections. According to the rules, this is legal..
See you at the regionals
Stills
Unread 21-02-2007, 13:42
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: ramp tractions
Originally Posted by Arefin Bari View Post
You aren't allowed to use any kind of tape or adhesive material on the robot.
I don't get that from the Q&A; there is a distinction made between adhesive backed tapes and other materials with adhesive backing. See this response. According to the GDC you can use adhesive backed traction materials as long as they are not tape. Likewise you can use adhesives (Spray 77, glue, contact cement, epoxy) other than tape - you could just take sandpaper and glue it to the surface.
Unread 21-02-2007, 13:47
GIR's Avatar
GIR GIR is offline
AKA: Pete
FRC #1335 (Cognitive Hazard)
Rookie Year: 1995
GIR is an unknown quantity at this point
Send a message via AIM to GIR
Re: ramp tractions
Have you considered friction tape like the kind they use on skateboards and hockey sticks?
Peter "Gir" Blais, Senior Advisor
Team 1335 - Raymond, NH
1996-1998: Student, Team 241
1999-2003: Mentor, Team 241
2004-2007: Mentor, Team 1335
Unread 21-02-2007, 14:59
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: ramp tractions
You may also want to look into alternatives from tape. Our team is using some kind of non-slip matting that one of our mentors picked up at home depot. Attach it using staples or zip ties, and you have no worries about breaking adhesive rules anymore.
Unread 21-02-2007, 15:42
Nate Edwards Nate Edwards is offline
SWARM Head Mentor
FRC #0957 (SWARM)
Nate Edwards will become famous soon enough
Re: ramp tractions
We thought of the skateboard tape when we designed ours, but we figured it was against the rules and I looked on the Q and A orginally they said no, so we just got some expanded metal which provides huge amouts of friction/traction.
Nate
South West Albany Robot Mechanics
2002 Pacific NW Regional Rookie All Star Award Winners
2003 Pacific NW Regional Daimler Chrysler Team Spirit Award Winners
2004 Pacific NW Regional Johnson & Johnson Sportsmanship Award Winners
2004 Pacific NW Regional Winning Alliance (492 (#1 Seed), 1031, 957)
2003 & 2005 Pacific NW Regional Chairman's Award Winners
2009 Oregon Regional Woodie Flowers Award Winner
Unread 21-02-2007, 16:50
Re: ramp tractions
Let me try to make this point again - there are no issues with adhesives. It's adhesive tapes that aren't allowed, not adhesives. Not to say that staples or zip ties might work better, but don't discount adhesives - they ARE allowed by the rules and confirmed by the Q&A.
Ramp dimensions Grovestand General Forum 7 13-01-2007 15:01
Motor Ramp Up/Ramp Down Function Tom Bottiglieri Programming 12 03-12-2006 23:31
Ramp or No Ramp Cyber Punk 234 Rules/Strategy 29 20-02-2006 18:42
To ramp, or not to ramp? phrontist Rules/Strategy 27 26-01-2006 17:56
Ramp archiver 2000 5 24-06-2002 00:08
