Go to Post So much energy is wasted complaining (even in this thread) and belittling others (subtly in this thread). You need to engineer an attitude that encourages success through hard work before you engineer the robot. - PayneTrain [more]
Unread 19-02-2007, 20:56
Andrew Blair's Avatar
FRC #0306 (CRT)
Sonar Function Issue
I am using the Maxbotics sensor, obtaining data through the AD, and need to find the difference between two consecutive readings. In the following, I have a distance function that returns the distance to the target in inches, and I use that number in the following function delta_distance() to find the difference between consecutive readings.
The problem is, when I run the thing, my return is always the inverse of the actual distance reading, and the issue is, solved with a printf, that my temp variable is never changing. It remains at zero constantly.
* FUNCTION NAME: distance
* PURPOSE:       returns a realtime distance from sonar, in inches
* CALLED FROM:   This file
* ARGUMENTS:
*     Argument       Type             IO   Description
*    none
* RETURNS:       unsigned int
unsigned int distance(void)
             return (unsigned int) Get_Analog_Value(rc_ana_in01)/s;
* FUNCTION NAME: delta_distance
* PURPOSE:      returns difference in range readings between cycles
* ARGUMENTS:
*    none
* RETURNS:       signed int
int delta_distance(void)
    int temp;
    temp -= distance();
    return (int) temp;
    temp=distance;
As well, if anyone can quickly through up a workable averaging function I'd be much obliged. I've tried without success, typically ending up with a constantly incrementing distance value, or erratic jumping output.
* ARGUMENTS:
*    none
 unsigned int temp;
 i++;
 unsigned int Distance;
 temp+= (Get_Analog_Value(rc_ana_in01)/2)
 if (i>=5)
          Distance=temp/i;
          i=0;
             return (unsigned int)Distance;
Thanks!
-Sir Francis Bacon
-Albert Einstein
Unread 20-02-2007, 12:02
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Sonar Function Issue
Team 95 has a huge number of IR sensors (BigHAIR: Big Honkin Array of IR sensors), and we keep time history and a running average on them. Here's a snippet
long IR_range[6]; // current ranges, generated by another function
long IR_range_history[6][4];  // Last 4 readings, not necessarily in order (see below)
long IR_range_average[6]; // running average of last 4 readings
void Average_IR(void) {
   static counter=0;
   index=counter++%4;  // Keeps from having to copy old data, just
                                 // overwrite one column at a time
   for (i=0;i<6;i++) {
        IR_range_history[i][index]=IR_range[i];
        IR_range_average[i]=0;
        for (j=0;j<4;j++) {
           IR_range_average[i]+=IR_range_history[i][j];
        IR_range_average[i]/=4;
Unread 20-02-2007, 13:39
...my temp variable is never changing...
    int temp;
    temp -= distance();
    return (int) temp;
    temp=distance;
The temp variable in your code evaporates as soon as delta_distance() returns. If you want to keep a local variable's value between calls to a function, you need to declare it static:
    static int last_distance = 0; // set to zero only on program start, retains value between function calls
    int delta;
    delta = distance()-last_distance; // compute difference between distances
    last_distance = distance(); // remember this distance for next time
    return delta;
SONAR Sensor Software Driver MikeDubreuil Programming 55 08-03-2008 11:03
Maxbotix Sonar Sensor DonRotolo Electrical 17 04-02-2007 12:27
VEX Sonar question Joohoo Programming 2 06-05-2006 01:18
Help with sonar sensor supertw Electrical 3 24-01-2006 23:41
FreeLibrary() Function Raven_Writer Programming 0 09-08-2003 15:39
