Go to Post Off-season events aren't just for gameplay, they should also be a training session for new students and rookie teams. - Bill Moore [more]
Unread 19-02-2007, 18:50
waiakea2024's Avatar
waiakea2024 waiakea2024 is offline
ZOMGWTHKTHXBAIBBQ!!!!
FRC #1056 (Kekoa o Haaheo)
waiakea2024 is a jewel in the roughwaiakea2024 is a jewel in the roughwaiakea2024 is a jewel in the rough
Delay Help!
We have been working on our autonomous mode and we cant figure out how to make a delay. Our mentor has tried to make his own but the bot wont recive it. Any Suggestions or ideas? Thanks!
Unread 19-02-2007, 18:59
Re: Delay Help!
We are trying to make our arm move and then stop without it hitting the ground and messing up the motor.
Unread 19-02-2007, 19:18
Ari Allyn-Feuer Ari Allyn-Feuer is offline
FRC #0753
Ari Allyn-Feuer is on a distinguished road
Re: Delay Help!
I would like to say that FFR, the real best way to do this is to have a quadrature encoder on the arm. But let's do it your way since that's the hardware!
Basically to make a delay, without going into using the onboard timers, is to increment a loop counter every loop and have a test statement which will do something when a certain number of loops has elapsed.
Pseudocode:
if(arm_is_moving && loops < NEEDED_LOOPS)
loops++;
if(arm_is_moving && loops = NEEDED_LOOPS)
arm_pwm=127;
arm_is_moving=0;
loops=0;
This is quick and ugly, and it would be more elegant to use the timers or have an encoder. But it'll work in a pinch.
I hope this helps. If we see each other at a regional I can help you some more, or post again or use a PM.
Ari.
Unread 19-02-2007, 21:58
Re: Delay Help!
that didnt work :l thanks for the help though
Unread 19-02-2007, 22:49
buddy.smith buddy.smith is offline
Master Control
FRC #1795
buddy.smith is an unknown quantity at this point
Re: Delay Help!
Well if you copied and pasted his code, then you should change the '=' to '=='
Also 'loops' will need to be static
ttyl,
--buddy
Unread 20-02-2007, 00:04
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Delay Help!
This is where a limit (either a software one from a shaft encoder or potentiometer) is good. Otherwise, if you really want a delay, let us know (there are several ways of doing this, ranging from crude (loop counting) to good (setting up a timer and interrupt routine to get real-time clocks)
Unread 20-02-2007, 12:47
Re: Delay Help!
well we just downloaded the WPILib and are currently trying to get it to download into our controller. Thanks to all for your advice. We have been trying many different things and we have officially run out of ideas. We are currently waiting for our mentor to see if he has any new ideas.
Unread 21-02-2007, 12:41
Re: Delay Help!
Thanks to everyone for the help and expertice. We finally got it and we are well on our way. Thanks again!
NERDS Delay... Andy Grady General Forum 21 14-03-2006 21:52
CMUCam 3 second startup Delay? Chris_Elston Programming 4 19-02-2006 09:33
Delay in autonomous mode SpeakerSilenced Programming 1 22-02-2005 10:58
Delay Gal Longin Programming 1 09-12-2004 10:37
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
