Re: Pneumatic Cylinder
That L-shaped component you are talking about is called a bell crank, and it requires a hinge point upon which it can rotate. Push perpendicularly to one end, and you get a force perpendicular to the other end. Vary the angle between the two arms and you change the directions of the input and output forces. Vary the lengths of the two arms and you change the mechanical advantage of the crank.
An example (two are shown): ![]() Last edited by Nate Laverdure : 20-02-2007 at 00:27. |
awesome thanx a lot
| Pneumatic cylinder size | bruss6 | Pneumatics | 8 | 16-02-2007 16:37 |
| pneumatic cylinder part numbers | Ed Crammond | Pneumatics | 0 | 14-02-2003 19:27 |
| Pneumatic Cylinder i-Factory Model Posted | Ed Sparks | Inventor | 0 | 12-01-2003 23:27 |
| Pneumatic Cylinder Length | billy | Technical Discussion | 2 | 10-01-2003 08:30 |
| 2" Pneumatic Cylinder Posted | Ed Sparks | General Forum | 0 | 27-01-2002 15:47 |
