Go to Post Robots will consume you if you are not careful. - JohnBoucher [more]
Unread 19-02-2007, 22:54
ambie_o7 ambie_o7 is offline
1056/2024 alum. 368 mentor
AKA: aMbIe
FRC #0368 (Team Kika Mana)
ambie_o7 is an unknown quantity at this point
Send a message via AIM to ambie_o7 Send a message via MSN to ambie_o7
How do we add WPILib files in prog???
Our team needs help... we dont know how to get the WPILib files to compile with the FRC code? we've added it into the source files and yet we still are having compiling probs... assistance is requested FAST... we want to pack it up tonite.... thanx guys!
Unread 19-02-2007, 23:11
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Re: How do we add WPILib files in prog???
Could you please describe the errors that it is showing? Also, make sure to set the link order so that WPILib is first, then the FRC library. This document describes how to check that on pages 7 and 8.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 19-02-2007, 23:17
AKA: aMbIe
errors include could not find UserAPI.h
we did put the WPILib files before...
thanxxxxxxxxxxxxxxxxxxxxxx!!!!!!!!!!!!!!!
Unread 20-02-2007, 00:28
MattD's Avatar
Ah, I think that it is actually named API.h in the distribution - try replacing any #include "UserAPI.h" lines with #include "API.h" instead, or you could just rename the API.h file to be UserAPI.h.
Unread 20-02-2007, 01:05
AKA: aMbIe
already tried that... that doesnt work either... thanxx n e way!!!
Unread 20-02-2007, 01:35
AKA: Brad
#0190 ( Gompei and the Herd)
It is correct that the UserAPI.h file is no longer used. I haven't had time to update the documentation.
Are there other errors that you are seeing?
Brad
Brad Miller
Robotics Resource Center
[wiki]: how to save more than one prog. in the RC Edourdo FIRSTwiki 1 04-02-2007 17:29
How to create 3D dxf files in Solidworks, Inventor, or other? Travis Covington SolidWorks 6 03-05-2006 21:46
CAD Help needed. Mech Desktop 6 files backwards to AutoCAD 14? (2d files) Elgin Clock Inventor 0 30-08-2004 23:06
how to add steps in the provided encoder program for the edu Zaramel2002 Programming 3 11-02-2004 08:35
How can we add color to etched aluminum??? archiver 2001 1 24-06-2002 01:02
