Go to Post Inspect every connection after every match. Use your eyes, ears and nose. - Al Skierkiewicz [more]
View Poll Results: What IDE did you use?
MPLab 34 53.97%
EasyC 11 17.46%
Eclipse 8 12.70%
FusionEdit 0 0%
Text editor/make 9 14.29%
Other(please post) 7 11.11%
Multiple Choice Poll. Voters: 63. You may not vote on this poll
Unread 18-02-2007, 20:00
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
What IDE DID you use?
We're two days from shipping so I thought I would get a realistic response now.
What programming environment did you use this year? Did you change during the season? If you changed why?
Eric Haskins KC9JVH
Unread 18-02-2007, 20:05
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: What IDE DID you use?
I used MPLAB all the way through, but I saw a few freaky things when I was using it (I'd be typing and gibberish would appear after the cursor as I was typing...a bit scary). Also, I'm thinking of switching to an Ubuntu-WinXP dual boot for next year, and that would interfere with the idea of using MPLAB again. I think I'll use an alternative method; I know there's something better out there.
JBot
Aren't signatures a bit outdated?
Unread 18-02-2007, 20:29
Ben Englert Ben Englert is offline
FRC #1072
Ben Englert has a spectacular aura aboutBen Englert has a spectacular aura aboutBen Englert has a spectacular aura about
I did prototyping in vi with gcc, and then brought it into MPLab to use the Microchip compiler. A fellow team member who uses Ubuntu was developing our compass interface code on a PIC16 used the free BoostC compiler with the SourceBoost IDE, but ended up having to use MPLab in VMWare to flash the chip with an ICD2 anyway.
Before a match at SVR, 3/17/06
Tatsu: "Yo Englert, what's our autonomous mode?"
Me: "We'll find out, won't we."
Both: *maniacal laughter*
After the match's autonomous period ends:
Me: "Well, the basic control system still responds. That's always good."
Both: *further laughter*
Unread 18-02-2007, 20:46
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Eclipse.
http://www.mikesorrenti.com/
Unread 18-02-2007, 21:00
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
I was planning to use Eclipse this year but never got around to setting it up on my new laptop, so i just used MPLAB cause it was run the installer CD and I was done, next year I will be using vi on our coproccessor and gcc or a python interpreter. I will also likely use Eclipse for whatever C code I write first as I have to have the standard drive code done b4 my team lets me play with the fun stuff
KK4KQO
http://voltair.us
Unread 18-02-2007, 21:13
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Originally Posted by Cuog View Post
I was planning to use Eclipse this year but never got around to setting it up on my new laptop, so i just used MPLAB cause it was run the installer CD and I was done, ...
Maybe next year, I can get CDs in all the kits. (I'll need lots of help!)
Unread 18-02-2007, 22:15
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
FIRSTclipse doesn't need 1400 CDs, but you do need a click-n-go installer available for download from SF that just plain works. I spent the better part of a day after school getting it to work on my machine, the trick ended up being specifing the library files w/o spaces (eg. C:\EXAMPL~1\E-PATH~1\IN-OLD-F~1\ORMAT~1\FRC_AL~1.LIB). Eclipse and the MCC18 tools also didn't play well at first with Subversion (Clean->Build All deleted some .svn directories and corrupted a repo I had going when I tried to commit the .hex files, luckily I was only 3 revs in from the default code). There were other issues as well, lots of tweaking paths-especially under Linker Information-and fiddling with MinGW make (which does work). It's just not as convienent as MPLAB.
However, I haven't run MPLAB since April of last year. Refactoring support, a quick diff viewer, and autocomplete are addictive, as is Ctrl+F3.
Other than that, I usually prototype with Dev-C++ when doing quirky C things like function pointers and Zend Studio 5.2 when just playing with program logic.
Robinson Levin
Unread 19-02-2007, 14:06
taylort taylort is offline
Lunatic! Lunatic!
AKA: Taylor Tsuboi
FRC #1293 (D5 Robotics)
Team Role: Student
taylort has a reputation beyond reputetaylort has a reputation beyond reputetaylort has a reputation beyond reputetaylort has a reputation beyond reputetaylort has a reputation beyond reputetaylort has a reputation beyond reputetaylort has a reputation beyond reputetaylort has a reputation beyond reputetaylort has a reputation beyond reputetaylort has a reputation beyond reputetaylort has a reputation beyond repute
Send a message via AIM to taylort Send a message via MSN to taylort Send a message via Yahoo to taylort
We used Code::Blocks, as well as just simple text-editing stuff.
Unread 19-02-2007, 23:00
buddy.smith buddy.smith is offline
Master Control
FRC #1795
buddy.smith is an unknown quantity at this point
We used a windows port of Vim, along with ctags. The project was built with MPLAB.
If anyone wants a good vimrc, let me know!
Unread 19-02-2007, 23:22
AKA: Jamie Bliss
However, I haven't run MPLAB since April of last year. [color=DarkOrange]Refactoring support, a quick diff viewer, and autocomplete are addictive, as is Ctrl+F3.
Robinson Levin
Yeah. Part of the problem is that GNU Make and the Makefile generator fights me. You have to do things like double quote (""C:\mcc18\lib"") to get it to work.
The other problem is that I don't think I can distribute MCC18 with it.
The only time MinGW fails is when you pass flags like "/w", which I think is required for MPASM.
I'll be the first to admit. FIRSTclipse has a long way to go. MCC18 and the CDT don't really mesh well. The error parser just fails miserably when using Wine.
All I can say is to help. Contribute code. Test new versions. Make packages. All I know is I can't do it all myself.
Unread 20-02-2007, 01:51
half geek's Avatar
half geek half geek is offline
For an extremely large value of 1/2
AKA: Greg R
None #0294 (Beach Cities Robotics)
Team Role: Student
half geek will become famous soon enough
Send a message via AIM to half geek
hehe.. This happened to me as well, but that is because one of the freshmen decided to turn our Qwerty keyboard into a Dvorak. Real funny....
73 de W6DXN k
Parse this:
g r e g a ``n o s p a m" r o b i ``a t" d e v ``d o t" j a v a ``d o t" n e t
Unread 20-02-2007, 15:11
JonathanLKS JonathanLKS is offline
Code::Blocks
FRC #0610 (The Coyotes)
JonathanLKS will become famous soon enough
Send a message via MSN to JonathanLKS
We also used Code::Blocks
Unread 21-02-2007, 00:26
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
We used an odd combination of KScope (GREAT program), emacs, and bluefish in combination with a Makefile. It worked very well, and we also utilized a subversion repository which really helped (revision 32 as of ship, we would've been at ~50 or more if we started it right at kickoff).
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 21-02-2007, 07:22
Billfred's Avatar
Billfred Billfred is offline
This is going to shock a few people, but none of the above. We have yet to push the program button on the 2007 RC; it's all running on default code. Some of that might change come Palmetto; for the amount of stuff we're doing to the code (read: not much), I expect to use MPLAB.
Unread 21-02-2007, 07:59
WaterFreak WaterFreak is offline
FRC #0708 (Hardwired Fusion)
WaterFreak is a splendid one to beholdWaterFreak is a splendid one to beholdWaterFreak is a splendid one to beholdWaterFreak is a splendid one to beholdWaterFreak is a splendid one to beholdWaterFreak is a splendid one to beholdWaterFreak is a splendid one to behold
I used SlickEdit for all of my code writing. It has an interface I am used to (use it all the time at work) and some way cool features, most powerful of which is a project wide search feature.
It does also NOT have some of the goofy window placement issues I had with MPLAB.
Naturally, still use MPLAB to compile the code.
Thanks, Jim Orr
Senior Software Engineer - Motorola, Connected Home
Supporting Team 708 - Hardwired Fusion
What programming environment did you use? StevenB Programming 10 18-03-2006 09:32
What did you use a calculator for on the ACT??? JoeXIII'007 Chit-Chat 8 27-12-2005 23:45
Drivetrain, what did you use? maclaren Technical Discussion 42 15-02-2004 21:09
What modeling program did you use? archiver 2000 5 23-06-2002 23:24
