Go to Post Sleep? What is sleep? - artdutra04 [more]
Unread 20-02-2007, 03:46
AKA: Dr. Brooks
no team (WRRF)
Re: The 8.2 (or 8.3) Battery Voltage Bug
Originally Posted by Terry Sherman View Post
We've seen the 8.3/8.2 Battery Voltage Bug yesterday and today with the following setup:
2007 controller
Beta 14 master firmware.
2007 radios.
2007 OI
We have the PROTECTED memory section defined in the linker command file.
We have the latest FRC 8722 Library file
Has any other teams seen the 8.2v bug resurface? Any ideas?
Thanks!
-Terry
Are you using any interrupts?
If so, what interrupts are you using and for what purposes.
<<< Let me be a little more transparent. All of the teams that I talked to last
year who were seeing this problem, after applying all the patches, were using
timer 3. I am interested in knowing if you are using timer 3. The patches
move things around in memory, and any movement of variables in memory
affected this problem, without really fixing it. We never saw the problem when
we backed away from interrupt use, although our interrupt based code was well
wrung out on prior year's controllers and never showed a problem. Knowing that
the chip was the same, and that the patches did not fix it for us last year, we
avoided any additional interrupt use in our code this year. One workaround worth
trying if you are not using the Kevin's camera code is to use his lastest code
that changes how the high number pwms are being handled. >>>
Eugene
Reading battery voltage in software RbtGal1351 Programming 17 21-10-2007 13:07
How to obtain battery voltage from within EasyC DavidSJohnson Programming 2 14-02-2006 00:05
battery voltage compensation Rickertsen2 Programming 5 17-10-2005 22:12
RC Circuits Melissa Nute Math and Science 3 25-01-2004 05:02
Battery Chargers Neal Probert Electrical 46 16-02-2003 22:31
