Go to Post That little voice in your head is not Ari telling you to keep going. It is your guardian angel telling you to stop! - Al Skierkiewicz [more]
Unread 20-02-2007, 08:17
Ianuser Ianuser is offline
FRC #0570
Ianuser is an unknown quantity at this point
Re: Gear Tooh phase B? help?
So quite literally:
void Encoder_2_Int_Handler1(void)
	// Encoder 2's phase a signal just transitioned from zero to one, causing
	// this interrupt service routine to be called. We know that the encoder
	// just rotated one count or "tick" so now check the logical state of the
	// phase b signal to determine which way the the encoder shaft rotated.
	Encoder_22_Count += ENCODER_2_TICK_DELTA;
#endif
#ifdef ENABLE_ENCODER_3
Also, this line of code wasn't compiling..it came up with this problem:
C:\USFIRST\frc_camera_s_21\CAMERA CODE\encoder.c:130:Error [1205] unknown member 'INT3IP' in '__tag_223'
C:\USFIRST\frc_camera_s_21\CAMERA CODE\encoder.c:130:Error [1131] type mismatch in assignment
for this line of code:
// interrupt 2 is low priority
	INTCON2bits.INT3IP = 0;
So I just commented it out. Do I still need it? I cant find anywhere in the code where it could be changed or anything.
Phase A and Phase B on encoders kiettyyyy Programming 11 12-04-2006 13:05
between phase scoring calculation question? psycho7 Rules/Strategy 2 08-01-2006 22:05
most important phase? Jeremy L Rules/Strategy 3 15-01-2003 15:21
Help Gear Ratios !!!!!!! Help sanddrag Technical Discussion 5 16-08-2002 15:09
1 or 2 phase switch archiver 2001 0 24-06-2002 00:48
