Go to Post "Things don't get done unless somebody does them." - CaptainKirby [more]
Unread 19-02-2007, 21:28
yanksrock777 yanksrock777 is offline
FRC #1468 (J-Birds)
yanksrock777 is an unknown quantity at this point
Send a message via AIM to yanksrock777
Pneumatic Cylinder
My team has a pneumatic cylinder that has been mounted almost vertically. The problem is that we need more of a lateral push rather than a vertical push. Now I was thinking we could fabricate a metal piece, some type of bracket that we could take that vertical push and transfer it into the direction that we need it. Any suggestions on what we could do? Some time of L shaped aluminum or something of that sort? In case you were wondering it is a pneumatic cyclinder to push out the ramps.
Unread 20-02-2007, 00:24
Nate Laverdure's Avatar
FRC #2363
Re: Pneumatic Cylinder
That L-shaped component you are talking about is called a bell crank, and it requires a hinge point upon which it can rotate. Push perpendicularly to one end, and you get a force perpendicular to the other end. Vary the angle between the two arms and you change the directions of the input and output forces. Vary the lengths of the two arms and you change the mechanical advantage of the crank.
An example (two are shown):
Unread 20-02-2007, 11:01
FRC #1468 (J-Birds)
awesome thanx a lot
Pneumatic cylinder size bruss6 Pneumatics 8 16-02-2007 16:37
pneumatic cylinder part numbers Ed Crammond Pneumatics 0 14-02-2003 19:27
Pneumatic Cylinder i-Factory Model Posted Ed Sparks Inventor 0 12-01-2003 23:27
Pneumatic Cylinder Length billy Technical Discussion 2 10-01-2003 08:30
2" Pneumatic Cylinder Posted Ed Sparks General Forum 0 27-01-2002 15:47
