Go to Post Prepare to be surprised, amazed, awed, and inspired. - Alan Anderson [more]
Unread 19-02-2007, 13:11
Konvicted's Avatar
Konvicted Konvicted is offline
AKA: konvicted
None #1408 (VOte for pancho)
Team Role: Electrical
Konvicted will become famous soon enoughKonvicted will become famous soon enough
how to put that light ?
We need help on how to wire the allen-bradley light....someone help please! robot is due today. We need it fast
Last edited by Konvicted : 20-02-2007 at 09:44. Reason: I attached a picture and didnot show.
Unread 19-02-2007, 13:36
Re: how to put that light ?
And we need a better description of what you need. Referring to "that light" might have worked if we could see where you were pointing, or if you had attached a picture of it. Please tell us what light you are talking about.
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
If you are talking about the diagnostic light, a diagram can be found here
Unread 19-02-2007, 16:33
JakeC JakeC is offline
FRC #1535 (The Knights of Alloy)
Team Role: Driver
JakeC is an unknown quantity at this point
Link is dead, and we need to know where that needs to go if it is a rule, someone help! We need to ship this robot!
ATTENDING:
Wisconsin Regional 2009
Greater Toronto Regional 2009- Winners Engineering Inspiration Award
Championship
Lets Go TKOA 1535!
Formally Known as the 1596 International Instigators
Unread 19-02-2007, 17:08
Jake et al,
This is not a critical part for you to ship your robot. Just make sure it is included in your shipping crate so that it arrives with your robot. An inspector or other teams will help you at your first regional to get it set up and working. Just be sure you have all the parts...One relay socket for the DIN rail, one relay to put in the socket, one PWM cable and one Amber Diagnostic light.
Unread 20-02-2007, 09:39
Konvicted's Avatar
AKA: konvicted
ALLEN-BRADLEY LIGHT
Unread 20-02-2007, 09:41
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
www2.usfirst.org/2007comp/other/2007_ROBOT_SIGNAL_LIGHT_R1.pdf
There's the correct link.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 20-02-2007, 09:46
Konvicted's Avatar
AKA: konvicted
thanks !
Unread 20-02-2007, 12:18
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
one word of advice: make sure you use the wiring diagram found in the official FIRST drawings (the link above). Do not use the one in the "Guidelines, Tips and Good Practices" manual. The diagram in the manual is a bit confusing, and the jumper from pin 1 to pin 4 of the digital relay is very easy to miss if you confuse it with part of the coil symbol on the drawing. Several teams have made this mistake, and assumed that their light was not working. When wired correctly (per the 2007_ROBOT_SIGNAL_LIGHT_R1 drawing), it should work fine.
-dave
Unread 20-02-2007, 12:23
Elgin Clock's Avatar
FRC #0237 (Black Magic)
-dave
Does an input signal from the field to the light when plugged into the official field control the power on the light, or should it light up under normal operation? (Re: Turning the bot on in the pits?)
We had an issue with it not lighting up, but assumed it may have been something that was controlled by the field, so didn't worry too much about it. We had confidence we would get the problem solved the Thursday of our first competition by asking other teams what it was supposed to do/did for them.
(Pesky little light doesn't need to give us headaches, when we have other more important things to worry about electrically before shipping.)
I don't know what diagram we used though, that may just be the problem.
Unread 20-02-2007, 12:48
El,
The light functions just like Team LEDs last year. Tether up and enable and you should see the LED on top of the relay and the Amber both light. If you don't see the relay light up (ours is kind of dim) then you have a wiring problem between the team color connectors and the relay or you have been shipped the wrong relay. If the relay is lighting up but the amber is not, you may have not installed the jumper on the relay from pin 1 to pin 4.
Unread 20-02-2007, 12:51
El,
Ok Thanks Al!
No biggie I guess, like I said, just one more thing to tweak Thursday at our first regional.
Thank you!
how do i put the picture next to my avatar????? call_me_Angles CD Forum Support 1 18-02-2006 10:17
pic: Guess What Put That Up There? 13something Robot Showcase 6 15-02-2005 19:45
How many computers can we put CAD on? DonsneverWRONG Inventor 1 23-01-2005 14:45
How to put Inventor pics on the web Andrew Schuetze Inventor 7 05-01-2005 13:59
How can I put a picture on my post CMC CD Forum Support 1 04-06-2001 09:26
