Go to Post what fun is it if you haven't ripped out all your hair and beaten your now bald head against the wall for extended periods of time.... - pickle [more]
Unread 20-02-2007, 12:52
Tz0m Tz0m is offline
FRC #0333
Tz0m is an unknown quantity at this point
Autonomous calculations
How exactly can I implement my formula to calculate distance into my autonomous code? I want the robot to move forward while the distance is greater than a certain number. If I use a while loop the rc crashes and does nothing. This is the code I have so far:
while (autonomous_mode || p3_sw_trig == 1) /* DO NOT CHANGE! */
if (statusflag.NEW_SPI_DATA) /* 26.2ms loop area */
Getdata(&rxdata); /* DO NOT DELETE, or you will be stuck here forever! */
// Start autonomous code
// call camera functions
Servo_Track();
Camera_Handler();
Tracking_Info_Terminal();
if (Get_Tracking_State() == CAMERA_ON_TARGET)
pwm13 = pwm14 = 104;
pwm15 = pwm16 = 150;
else if (Get_Tracking_State() == SEARCHING)
pwm13 = pwm14 = 150;
pwm15 = pwm16 = 104;
// End autonomous code
PWM(pwm13,pwm14,pwm15,pwm16);
Putdata(&txdata); /* DO NOT DELETE, or you will get no PWM outputs! */
How can I build my code around this?
Motor Calculations John Gutmann Motors 3 25-06-2006 08:39
Volume/Weight Calculations in Inventor =Martin=Taylor= Inventor 2 08-04-2006 10:21
Distance calculations Max Brin Programming 3 22-02-2006 21:38
Autonomous danielkitchener Rumor Mill 3 03-01-2004 01:08
Seeding Calculations archiver 2000 50 23-06-2002 21:57
