Go to Post It may not happen overnight, but in time if you keep focused and keep working hard, it will become a reality. - Michael Sperber [more]
Unread 19-02-2007, 20:56
Andrew Blair's Avatar
FRC #0306 (CRT)
Sonar Function Issue
I am using the Maxbotics sensor, obtaining data through the AD, and need to find the difference between two consecutive readings. In the following, I have a distance function that returns the distance to the target in inches, and I use that number in the following function delta_distance() to find the difference between consecutive readings.
The problem is, when I run the thing, my return is always the inverse of the actual distance reading, and the issue is, solved with a printf, that my temp variable is never changing. It remains at zero constantly.
* FUNCTION NAME: distance
* PURPOSE:       returns a realtime distance from sonar, in inches
* CALLED FROM:   This file
* ARGUMENTS:
*     Argument       Type             IO   Description
*    none
* RETURNS:       unsigned int
unsigned int distance(void)
             return (unsigned int) Get_Analog_Value(rc_ana_in01)/s;
* FUNCTION NAME: delta_distance
* PURPOSE:      returns difference in range readings between cycles
* ARGUMENTS:
*    none
* RETURNS:       signed int
int delta_distance(void)
    int temp;
    temp -= distance();
    return (int) temp;
    temp=distance;
As well, if anyone can quickly through up a workable averaging function I'd be much obliged. I've tried without success, typically ending up with a constantly incrementing distance value, or erratic jumping output.
* ARGUMENTS:
*    none
 unsigned int temp;
 i++;
 unsigned int Distance;
 temp+= (Get_Analog_Value(rc_ana_in01)/2)
 if (i>=5)
          Distance=temp/i;
          i=0;
             return (unsigned int)Distance;
Thanks!
-Sir Francis Bacon
-Albert Einstein
Unread 20-02-2007, 12:02
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Sonar Function Issue
Team 95 has a huge number of IR sensors (BigHAIR: Big Honkin Array of IR sensors), and we keep time history and a running average on them. Here's a snippet
long IR_range[6]; // current ranges, generated by another function
long IR_range_history[6][4];  // Last 4 readings, not necessarily in order (see below)
long IR_range_average[6]; // running average of last 4 readings
void Average_IR(void) {
   static counter=0;
   index=counter++%4;  // Keeps from having to copy old data, just
                                 // overwrite one column at a time
   for (i=0;i<6;i++) {
        IR_range_history[i][index]=IR_range[i];
        IR_range_average[i]=0;
        for (j=0;j<4;j++) {
           IR_range_average[i]+=IR_range_history[i][j];
        IR_range_average[i]/=4;
Unread 20-02-2007, 13:39
...my temp variable is never changing...
    int temp;
    temp -= distance();
    return (int) temp;
    temp=distance;
The temp variable in your code evaporates as soon as delta_distance() returns. If you want to keep a local variable's value between calls to a function, you need to declare it static:
    static int last_distance = 0; // set to zero only on program start, retains value between function calls
    int delta;
    delta = distance()-last_distance; // compute difference between distances
    last_distance = distance(); // remember this distance for next time
    return delta;
SONAR Sensor Software Driver MikeDubreuil Programming 55 08-03-2008 11:03
Maxbotix Sonar Sensor DonRotolo Electrical 17 04-02-2007 12:27
VEX Sonar question Joohoo Programming 2 06-05-2006 01:18
Help with sonar sensor supertw Electrical 3 24-01-2006 23:41
FreeLibrary() Function Raven_Writer Programming 0 09-08-2003 15:39
