Go to Post The only thing "an eye for an eye" has ever settled is two eyeless people. - Cory [more]
Unread 20-02-2007, 12:52
Tz0m Tz0m is offline
FRC #0333
Tz0m is an unknown quantity at this point
Autonomous calculations
How exactly can I implement my formula to calculate distance into my autonomous code? I want the robot to move forward while the distance is greater than a certain number. If I use a while loop the rc crashes and does nothing. This is the code I have so far:
while (autonomous_mode || p3_sw_trig == 1) /* DO NOT CHANGE! */
if (statusflag.NEW_SPI_DATA) /* 26.2ms loop area */
Getdata(&rxdata); /* DO NOT DELETE, or you will be stuck here forever! */
// Start autonomous code
// call camera functions
Servo_Track();
Camera_Handler();
Tracking_Info_Terminal();
if (Get_Tracking_State() == CAMERA_ON_TARGET)
pwm13 = pwm14 = 104;
pwm15 = pwm16 = 150;
else if (Get_Tracking_State() == SEARCHING)
pwm13 = pwm14 = 150;
pwm15 = pwm16 = 104;
// End autonomous code
PWM(pwm13,pwm14,pwm15,pwm16);
Putdata(&txdata); /* DO NOT DELETE, or you will get no PWM outputs! */
How can I build my code around this?
Unread 20-02-2007, 13:50
Re: Autonomous calculations
The User_Autonomous_Code() function is a while loop. Put your calculation in the middle of it, where it will be executed every time through the loop.
Do you want the calculation to be made only when the camera is locked on the light? If so, put it inside the first if.
bcieslak
Posts: n/a
We use the value of tilt servo to tell us when we want to stop. As we get closer to the light the camera must look up higher. Tilt servo value decreases the higher we look. When we get below a certain value we stop.
Determine different tilt servo values associated with different distances from the target to create a ranging system..OR create a formula to convert tilt servo value to distance from light.
BC
Unread 20-02-2007, 14:26
Mandi_|<o>|'s Avatar
Mandi_|<o>| Mandi_|<o>| is offline
AKA: Marina Stetner Dias
Mandi_|<o>| will become famous soon enoughMandi_|<o>| will become famous soon enough
Send a message via ICQ to Mandi_|<o>| Send a message via MSN to Mandi_|<o>|
BC
That's what I'm doing, the problem is, we made an auto-pan routine that takes us near the target, but sometimes we get there diagonally. We're still looking for the perfect routine, unfortunately it seems to be very far...
Mandi | F(RC + LL) Volunteer
Unread 20-02-2007, 14:36
FRC #0333
Thanks for the help. Just for testing, we tried using the tilt servo value to get it to stop. This is our code:
if ((int) TILT_SERVO < 170)
pwm15 = pwm16 = 157;
else if ((int) TILT_SERVO > 170)
pwm13 = pwm14 = pwm15 = pwm16 = 127;
However, the robot continues to drive forward. The camera seems to stop moving once we initiate autonomous mode. We have these three functions, Servo_Track(); Camera_Handler(); and Tracking_Info_Terminal();, called right after Getdata(&rxdata);.
Unread 24-02-2007, 06:15
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
hmmm...mabye you should try with angles? take the calculation of the tilt angle from terminal.c and find what is your requested tilt angle where the robot will stop in your opinion and then do the tilt angle in relation to the distance(too far, go forward. too close, stop.).
Shouldn't be too complicated and it worked for us, but if you prefer to use your own function like that, I have no idea what the problem can be...
Motor Calculations John Gutmann Motors 3 25-06-2006 08:39
Volume/Weight Calculations in Inventor =Martin=Taylor= Inventor 2 08-04-2006 10:21
Distance calculations Max Brin Programming 3 22-02-2006 21:38
Autonomous danielkitchener Rumor Mill 3 03-01-2004 01:08
Seeding Calculations archiver 2000 50 23-06-2002 21:57
