Go to Post What I want is to ultimately make it so that the programming is actually done before the robot is finished. Imagine that! - Danny Diaz [more]
Unread 20-02-2007, 16:32
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
Re: Robot Disabled, yet I can still actuate a Cylinder- HELP!
Originally Posted by Dave Flowerday View Post
You do have the pump and claw relays plugged into a relay output (and not a digital I/O), right? Sorry, I know it probably sounds like a stupid question, but if so it could explain why things work when disabled. If it is a relay output (and the OI disabled light is solid orange) then that's a scary situation indeed.
No Dave, it's not a stupid question- it IS plugged into a Digital I/O connector.
I swear the OI disabled light is solid orange. If the robot wasn't crated I'd put a video up.
Could you, uhhh, kindly relate why the IO might be triggering it this way?
(Wired, from memory, from the student that told me this is how:
Digital IO pin 16 to SPIKE relay, relay to valve, vale to cylinder.
Unread 20-02-2007, 16:39
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Digital I/O are NOT for SPIKEs. There is a reason for the 8 relay outputs on RC...
Digital I/O are always active!
Unread 20-02-2007, 16:47
No Dave, it's not a stupid question- it IS plugged into a Digital I/O connector...Could you, uhhh, kindly relate why the IO might be triggering it this way?
Digital outputs do not get disabled.
Your robot is wired illegally.
Move the Spike to a relay output NOW (or as soon as you get your robot out of its crate at a competition).
Unread 20-02-2007, 16:52
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
That would be your problem. As others have already pointed out, Spikes need to be on the relay outputs only. Digital I/Os are meant for inputs like sensors or benign outputs like LEDs.
Unread 20-02-2007, 17:01
AKA: Jason
FRC #3015
*ducks and hides*
Thanks all. I'm guessing that the compressor shouldn't be wired to the digital IO either... ?
Limit switches OK?
Unread 20-02-2007, 17:14
esquared's Avatar
esquared esquared is offline
Keeps saying 3-2-1-Rush...
AKA: Angry Eric
no team (Volunteer!)
Team Role: Mascot
esquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond repute
Limit switch good for Digital I/O.
Compressor bad for Digital I/O.
What is the Spike output wiring going to the compressor? The compressor is not fond of being driven in reverse...
Unread 21-02-2007, 08:08
AKA: Jason
FRC #3015
Compressor runs forward correctly- we're careful like that....
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
Unread 21-02-2007, 15:20
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
We tested it in reverse for a few seconds, just to see what happens (we were hunting for a short circuit). It appears to have run properly...
Unread 21-02-2007, 16:39
esquared's Avatar
AKA: Angry Eric
Team Role: Mascot
The compressor documentation states to avoid running it in reverse. I would hope it wouldn't blow up in the course of a few seconds, but where pneumatics are concerned better safe than sorry
HELP NEEDED! Camera twitches while disabled lkdjm Programming 5 19-02-2007 11:34
Can we still go? Michael Corsetto Championship Event 1 22-03-2006 06:23
LEGO ‘engineers’ compete to help the disabled Billfred FIRST In the News... 1 07-02-2005 13:45
can i use any other custom cylinder MAXbattlebot Pneumatics 2 19-01-2003 12:44
