Go to Post If they need a place where they can get a chance to learn interpersonal skills (like a team), it might just help them to become well-adjusted adults, as opposed to pathologically antisocial engineers (who got good grades). - Tristan Lall [more]
Unread 20-02-2007, 16:57
LieAfterLie's Avatar
LieAfterLie LieAfterLie is offline
FRC #2028
LieAfterLie is an unknown quantity at this point
Keyang Motor Gear Profile
Does anybody know what the gear profile is on the keyang worm gear motors (the power window motors) in the KOP, or where I can go to look up the profile? We need to buy 2 gears with a 4:1 ratio to the motor for our arm.
SEMPER UBI SUB UBI
Unread 22-02-2007, 09:57
mentorDon's Avatar
mentorDon mentorDon is offline
FRC #1764
mentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these parts
Re: Keyang Motor Gear Profile
We used a 12 DP to match the Keyang
Unread 22-02-2007, 10:23
psquared89's Avatar
psquared89 psquared89 is offline
AKA: Pat Pannuto
FRC #0245 (Adambots)
Team Role: Driver
psquared89 is a jewel in the roughpsquared89 is a jewel in the roughpsquared89 is a jewel in the roughpsquared89 is a jewel in the rough
They are not standard by any means. We ended up going at them with calipers and making a CAD model of the gear by hand. One of our team mentors was able to get them water-jetted and that's how we made them.
If you're interested, I can see if I can hunt down the CAD files. Even those weren't quite exact though, we pushed it through and arbor press a few times before it gave a nice clean fit.
At the end of the game, the King and the Pawn both go back into the same box.
~ Italian Proverb
adambots.com
Unread 22-02-2007, 10:27
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
At those types of speeds 12 DP is a close fit. I believe Dr. Joe once mentioned that they're a stub tooth profile.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 22-02-2007, 10:57
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The stub tooth was on the Nippon-Denso window motors. I'm unsure if the Keyang is the same, but you could buy a gear and try it. A stub gear uses one DP for the tooth thickness and number, and a second, smaller DP for the addendum, dedendum, pitch diameter, height, etc. So if a 12DP gear fits, then it might be a 12DP stub. In which case you'd might have a better mesh if you turned down the 12DP gear to the OD of a 14 DP gear. Ish. I think it's pretty complicated.
Unread 23-02-2007, 17:00
FRC #2028
Thanks. 12 it is, that's what I got too. Is the pressure angle 12.5 or 20? Does it matter? How do I tell? Would it matter if it's a stub gear? How do I tell? Anything else that would make it incompatible with a normal spur gear?
Could someone tell me some good sites to find aluminum or brass gears? I need 2 12 DP gears with about 36 teeth. McMaster, Grainger and RobotCombat only have steel ones that I could find, wich weigh about 2.5 lbs each with 3" pitch diameters, which is way too much. I don't want to have to drill out a whole lot.
SEMPER UBI SUB UBI
Unread 23-02-2007, 17:16
WM Berg
But I hope you have time and money. They list that particular combination as around $40 and the stock is either 2 weeks or "call berg"
EDIT: They appear to have minimal stock of a 12 DP, 3.5" PD gear, if that's an option
2 motor adapter and keyang motor dimensions Bruno Estevão General Forum 1 16-02-2007 09:36
keyang motor wedellm Motors 2 14-02-2007 02:37
Keyang Window Motor Gear pitch AdamHeard Technical Discussion 3 19-01-2007 12:12
Denso Window Motor gear profile? Joshua Lynn Inventor 2 23-01-2006 23:57
Internal vs. External Gear teeth - same profile? sanddrag Technical Discussion 7 01-03-2005 10:44
