Go to Post We will all win in the end. - JaneYoung [more]
Unread 20-02-2007, 18:53
Gherkinman's Avatar
Gherkinman Gherkinman is offline
Native German Pickle
AKA: Odin All Father
no team (Thor)
Rookie Year: 1342
Gherkinman is an unknown quantity at this point
Send a message via AIM to Gherkinman
How do motion constraints work?
I'm having a problem getting some constraints to work properly. Basically, I made some pneumatic pistons and constrained the bore to the tube. They line up properly but the tube sticks out the same direction as the bore instead of towards it, so the bore isnt inside the tube like it should be. I cant just flip the tube around because the contraint "works" and the two parts move together.
I tried isolating and editing the whole assembly but when i edit it, it appears fine. Then I finish edit and it's backwards again.
I figure if I can somehow contrain the bore to move only within the tube caps it will both:a) Not look so bad by sticking out if its moved too far and, b) Actually get in the tube!
Can anybody provide some insight on this dellemma/ tell me how i can take a screenshot so i can explain it better? Thanks.
Unread 20-02-2007, 18:59
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Re: How do motion constraints work?
Zip and post your files here
http://discussion.autodesk.com/forum.jspa?forumID=78
should take only a few minutes to fix.
Unread 20-02-2007, 19:03
Gherkinman's Avatar
no team (Thor)
Rookie Year: 1342
Will do, seriously though. How do you take a screenshot? I press print screen like 5,000,000 times
Unread 20-02-2007, 19:07
Try shift and printscreen. At least on my keyboard, that's how it works. (I think)
As for the constrain, try doing a flush constraint with an offset between the end of the pison rod and the end of the cylinder you want it at (then removing that constraint later.)
Unread 20-02-2007, 20:16
Gherkinman's Avatar
no team (Thor)
Rookie Year: 1342
I posted the .zip on the autodesk forums under "116 grabber contraint issues"
Unread 20-02-2007, 20:49
spinmunky's Avatar
spinmunky spinmunky is offline
Mechanical/Photographer/Photoshoper
AKA: LJ (Little John)
FRC #0100 (The Wildhats)
Team Role: Driver
spinmunky will become famous soon enough
Send a message via AIM to spinmunky Send a message via MSN to spinmunky Send a message via Yahoo to spinmunky
press print screen then go into a image editing program (ex.Paint) then ctrl+v (paste)
"FIRST is like the WWF, but for smart people" -George Herbert Walker Bush
Unread 20-02-2007, 20:59
rohit's Avatar
rohit rohit is offline
Inventor Person
FRC #0617 (The Springers)
rohit has a spectacular aura aboutrohit has a spectacular aura about
Send a message via AIM to rohit
First, put a constraint on the axis of the 2 cylinders, and then use a flush constraint to get the rod aligned
Unread 22-02-2007, 20:18
Gherkinman's Avatar
no team (Thor)
Rookie Year: 1342
Thanks for your help guys, the problem has been resolved
Placing inventor assemblies with motion constraints rohit Inventor 2 03-02-2007 16:50
constraints in assemblies Adama Inventor 7 04-12-2006 16:20
How does it work? Ryan O Control System 5 12-03-2006 19:15
How Segways Work tkwetzel Dean Kamen's Inventions 0 12-11-2004 06:34
how do nationals work Rob36 Championship Event 3 10-01-2003 18:31
