Re: pic: Our spine
Is it safe to assume that you guys have some clever control, or are you manually controlling the tension on the cables? |
Re: pic: Our spine
Unfortunatly the motors for the arm dont have encoders, however we dont really need them. I will say we do have "somthing special'' that helps with control.
Re: pic: Our spine
A miniature model of the robot?
Re: pic: Our spine
Nope its part of our actual robot.
Re: pic: Our spine
I think he was talking about how to control the spine. You could control it with a model, if it was designed cleverly.
Re: pic: Our spine
Im sorry im not following could you please explain?
#7
Re: pic: Our spine
What he is stating is that you could make a miniature version of your arm in order to control your robot, you have a feedback sensor on the model on the points of movement, and you have the same on the larger version and you just work it in the code to say when this is he (on the mini) this goes here (on the real one), im not sure of how its exactly done, but i have seen it done before |
#8
Re: pic: Our spine
Oh i get it know, crap now why didn't we think of that. Its a good idea unfortunately we didn't think of it and probably wouldn't of had time to do it.
#9
Re: pic: Our spine
Guess' for control:
1. A resisting flex seonsor allowing for the approximate bend of the antenna to be read. 2. A camera that looks for a "green blob" on the end. and coolest (but least likely)... 3. Your using a fiber-optics cable and analyzing the light distortion to find how your bent!!!! ![]() |
#10
Re: pic: Our spine
The most direct (and probably easiest) method would just be to build a miniature version of the arm and put potentiometers where the motors would interface. Then you just read the pot values and map them.
If you design it, you can build it into a project box the size of a joystick base during your fix-it windows, and just plug it in at competition |
#11
Re: pic: Our spine
that is crazy i cant wait to see it in action at the FL regional
I think we are using the same mecanum wheels as you guys |
#12
Re: pic: Our spine
This is def. gunna b the bot i want to go check out at atlanta! way cool and u need to release a video
#13
Re: pic: Our spine
I have been fortunate enough to see the prototype of this arm in action and I can vouch for its extreme awesomeness. Its probably one of the coolest arms that I have ever seen attached to a FIRST robot.
| pic: Our crate | LightWaves1636 | Extra Discussion | 13 | 08-04-2007 02:00 |
| pic: Team 842 Tranmission Spine | falconmaster | Extra Discussion | 16 | 12-01-2007 03:01 |
| pic: Our robot | ryan_f | Robot Showcase | 12 | 15-02-2005 02:00 |
| pic: Our Animator | CD47-Bot | Extra Discussion | 5 | 31-03-2004 19:09 |
| pic: Our Bot | CD47-Bot | Robot Showcase | 0 | 04-03-2003 19:21 |
