Go to Post The strive for the Chairman's award is by far more important than the award. - Pavan Dave [more]
Unread 20-02-2007, 19:36
robonerd6969 robonerd6969 is offline
robonerd6969 is an unknown quantity at this point
Re: wii controller
its against the rules no doubt, its just really cool and i wanted to know how it worked, wierd tho, cuz it was completely wireless and it wasnt hooked up to a pc...team 1661 is really good with electronics i guess...
heres a new question on the table, how many robotics nerds does it take to figure out how to hook up a wiimote to an operator interface?
Unread 20-02-2007, 20:00
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
Re: wii controller
I don't think it's against the rules.
<R83> All equipment connected to the joystick ports of the Operator Interface must be powered solely through the power available through the port. External power sources of any type are not permitted on any equipment connected to the joystick ports. Portable computing devices can not be connected to joystick input ports on the Operator Interface. Power-passive devices (e.g. joysticks that draw their power solely through the Operator Interface joystick port) are permitted. The one exception to this rule is Innovation First incorporated USB adapters (IFI Part Number USB-CHICKLET) may be used to connect USB devices to the joystick ports of the Operator Interface. If used, this USB adapter must be powered with a 7.2V battery similar to the back-up battery. Teams can not use power from the competition port or any other source to power the USB adapter. The USB adapter must be positioned within the OPERATOR CONSOLE so that the indicator lights may be seen during inspection and operation in a match.
IMHO, there are two reasons for this rule:
1. So that we don't fry the OI
2. So that we can't have a computer run our robot (though you could just as easily put a computer onto the robot itself...)
It says that anything attached to the joystick ports is not allowed to have an external power source. The wiimote would not be attached to the joystick ports, and therefore should be legal. The wiimote also doesn't really violate either of the reasons I can think of for this rule, so I don't see any reason why it should be illegal.
The rule about extra radios is this:
<R66> The radio modems provided in the 2007 Kit Of Parts are the only permitted method for
communicating with the ROBOTS during the competition. Radio modems from previous
FIRST competitions can not be used. The radio modem must be connected directly to the
Robot Controller using one of the DB-9 cables provided in the 2007 Kit Of Parts. No other
form of wireless communications can be used to communicate to, from or within the ROBOT
(e.g. no Bluetooth devices are permitted on the ROBOT).
Says nothing about extra radios attached to the OI.
However, if I were a judge I might be a little wary of having a radio attached to the OI. I could see a non-GP team having someone in the stands control the robot.
Unread 20-02-2007, 20:08
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: wii controller
It would be illegal because of R66:
<R66> The radio modems provided in the 2007 Kit Of Parts are the only permitted method for communicating with the ROBOTS during the competition. Radio modems from previous FIRST competitions can not be used. The radio modem must be connected directly to the Robot Controller using one of the DB-9 cables provided in the 2007 Kit Of Parts. No other form of wireless communications can be used to communicate to, from or within the ROBOT (e.g. no Bluetooth devices are permitted on the ROBOT).
...combined with R11:
<R11> For the purposes of determining compliance with the weight and volume limitations specified in Rule <R07>, these items are NOT considered part of the ROBOT and are NOT included in the weight and volume assessment of the ROBOT:
- The OPERATOR CONSOLE.
However, for all other purposes the items listed above are considered part of the ROBOT and must comply with all other applicable rules and requirements. In particular, these items are subject to the shipping deadlines specified in Section 4.5.1.1 and must ship in the crate with the rest of the ROBOT.
So, the operator console is part of the robot and must follow all robot rules. R66 says no wireless communication can be used other than the radio modems.
Unread 20-02-2007, 20:12
Re: wii controller
I'll give you that. I wasn't aware of that rule.
However, in my opinion a wiimote attached to the OI still doesn't violate the reasoning behind the rules. Remember that we're not supposed to 'lawyer' the rules, but instead consider the purpose behind them. I think any team which can manage to get a wiimote hooked to an OI, and have it control the robot intelligently should not be penalized. Instead, they should be given an award.
Unread 21-02-2007, 08:14
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: wii controller
QUOTE=meatmanek;582808] I think any team which can manage to get a wiimote hooked to an OI, and have it control the robot intelligently should not be penalized. Instead, they should be given an award.[/quote]
Yes, I agree. The Chicklet supports a wireless gamepad. We use the wireless for debugging and testing. It is great, you never have to get up from your computer to "man" the controls, you can walk behind the robot to get different perspectives. They operate at 2.4 GHZ and should not cause any interferance with the radios. We are not using it because we are not certain about the rule.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 23-02-2007, 23:59
Grant Cox's Avatar
Grant Cox Grant Cox is offline
Back for more.
FRC #0148 (Robowranglers)
Team Role: Tactician
Grant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond repute
Re: wii controller
I actually was wondering if someone would be able to make that work. Using the GlovePIE scripts available online, it's more than plausible that you could rig something so that wii_accelerometer_up = globemotor_forward.
Come on FIRST, loosen those wireless controller restrictions
VEX Robotics Marketing Manager
ThunderChicken driver '07-'08
Robowrangler '13-present
FIRST in Michigan, VEX Worlds, and FIRST in Texas MC/Game Announcer '08-present
Unread 24-02-2007, 00:07
Re: wii controller
We had something like this running.
GlovePIE would rip all of the WiiMote Datas (yes, datas) off of the controller and export it to a virtual parallel port joystick.
Then we had a python script that would read the button and analog axis values from the virtual joystick, bundle it up, and shoot it over serial. On the RC side, we had software running to rip the Wiimote datas out and map them to motors and such.
Getting this to work with the OI would be super cool though.
360, Wii, or PS3 JoeXIII'007 Chit-Chat 58 10-04-2008 01:29
Wii Friend Code Exchange Joe Matt Chit-Chat 10 19-04-2007 20:20
pic: ChiefDelphi on my Wii Michelle Celio Chit-Chat 38 16-02-2007 18:31
Nintendo Revolution (wii) Futbol.195 Games/Trivia 2 20-10-2006 09:18
Nintendo Wii: $250; November 19 Brian Lesser Chit-Chat 11 17-09-2006 12:41
