Go to Post Oh, and a general guiding principle: Don't be stupid. - Billfred [more]
Unread 20-02-2007, 22:29
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: New Robotics Lab design needs your input
What layout ? Carpet area with mock field space, (half of your lay out), 1/3 of it for building, 1/3 for Machines, 1/3 of remaining for a MOCK Pit so your team gets idea of working at regionals.
|...........|________|
What tools ? A Lathe, Mill, CNC, Drill Press, Ban saw, Grinder, Dremel, Drills, et cetra.
What kind of storage? Cabinets, Shelves, Tables with shelves underneath
What built in systems (air, vacuum, power) ? Air and Power. If you
Cabinets, shelves, closets? Many Cabinets....One for EACH sub system or group on your robot and a huge cabinet for each to put their stuff away at night possibly.
Floor covering - workshop and classroom Cement is preferable IMO because you can always lay carpet for field, and if you spill something or when its time to clean, it is easier on concrete.
Overhead systems (unistrut, power, lighting)? WHITE LIGHTS! Make sure you have white lights.
Also see if you can get a room by the wall of the building so that you can install a retractable wall/gate so you can ship your bot and move it out of the building easier.
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
S.O.A.P. Changes: Your Input Needed! Silence Scouting 12 30-01-2005 18:02
Arm Design Input -- Four Bar Linkages Sachiel7 Technical Discussion 4 18-01-2005 01:29
a Boston Invitational... I WANT YOUR INPUT!!! Erin Rapacki Off-Season Events 30 30-03-2003 14:33
Time limits, your input, etc. Brandon Martus Announcements 36 08-11-2002 07:50
