Go to Post I swear, at IRI, Gary and I only talked about coming up with a plan to do away with Billfred, we didn't actually do anything... yet... - MissInformation [more]
Unread 21-02-2007, 01:54
shtylman shtylman is offline
some sort of programmer
FRC #2420
shtylman has a spectacular aura aboutshtylman has a spectacular aura about
Re: changing main.c
Originally Posted by Alan Anderson View Post
Consider yourself corrected. Take a look at the main() function in main.c and you'll see that it calls Process_Data_From_Master_uP() just before checking autonomous_mode. So it calls the "slow loop" code continuously before going autonomous, and then calls it one more time after autonomous is enabled and before calling User_Autonomous_Code().
In the default Code, Process_Data_From_Master_uP is only called once before autonomous if the OI is set to run autonomous mode. After the RC goes into autonomous mode, the while loop in the autonomous code blocks and Process_Data_From_Master_uP is not called again until autonomous code ends.
The reason for calling it first is most likely that teams usually run the regular code and not autonomous. Whatever the case, a Getdata must be called with the rx_data struct so the data can be retrieved from the master processor about which mode to go into. I have not done it myself, but I am confident that you can simply change
if (statusflag.NEW_SPI_DATA) /* 26.2ms loop area */
{ /* I'm slow! I only execute every 26.2ms because */
/* that's how fast the Master uP gives me data. */
Process_Data_From_Master_uP(); /* You edit this in user_routines.c */
if (autonomous_mode) /* DO NOT CHANGE! */
User_Autonomous_Code(); /* You edit this in user_routines_fast.c */
to ->
Getdata(&rxdata);
else
In main.c
And you will not run user code and yet still be ok. Someone should try this if they have a spare RC around (ours got shipped today and I don't have access to old robots). Just my $0.02
main.c 6600gt Programming 3 29-08-2006 02:19
Main Battery Cables maclaren Electrical 14 26-07-2006 12:37
Editing Main.c Astronouth7303 Programming 22 20-02-2004 16:45
Main Stage archiver 2001 3 24-06-2002 03:06
main driver Kaitlin Palmer Off-Season Events 0 09-04-2002 21:26
