Go to Post Backwards PWMs happen to the best of us. - Woolly [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 21-02-2007, 10:03
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Re: Back-up Battery question
We'll also be pulling the breaker supplying it when the robot is not in use
It is also best to disconnect the backup battery from the on-board charging circuit. Without an attached RC or connection on the 12V supply end the circuit still discharges through the charging circuit to ground. Granted we only measured 6-8ma, but why start off with a partially discharged battery. With supply side connected but without the main battery the discharge rate will be much higher (assuming things like victor fans, etc. are directly connected to breakers and not via spikes).
battery question hiimcristhian General Forum 6 09-02-2007 11:38
Battery question CraigHickman Electrical 9 23-10-2006 21:55
Back-up battery charging circuit from IFI Don Wright Electrical 19 02-05-2006 20:41
Back up battery Jeremy General Forum 3 25-02-2004 09:56
Looking for Back up Battery? PMGRACER Kit & Additional Hardware 11 16-01-2004 12:15
