Go to Post It's better to be safe than sorry. - Dan Petrovic [more]
Unread 21-02-2007, 11:03
Bharat Nain's Avatar
Re: Motors heating up..Plz ASAP
1) Make sure they are not connected directly to the battery. Run them through a breaker panel and speed controller.
2) Make sure they are running in the same direction and not fighting against each other. Do this one by one. Make sure the program is configured correctly for these motors. You can either use two PWM cables or one Y-PWM cable. Either way make sure it is programmed correctly.
That's about it. Although you might have already burnt up your motor. Good luck.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 21-02-2007, 11:08
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
If they're heating up then there must be current running throught them. They're probably being stalled.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 21-02-2007, 11:50
Back after 4 years off
FRC #5279
Originally Posted by Bharat Nain View Post
You can either use two PWM cables or one Y-PWM cable. luck.
You can only use a y cable if the two motors are facing in the same direction or one is wired backwards.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 21-02-2007, 11:51
Electrical Engineer
Rookie Year: 1995
1) ...Although you might have already burnt up your motor. Good luck.
Window motors should not "burn up". They usually have thermal resistances built in to reduce current in the event of a stall. This is supposed to keep your car window from crushing an arm (neck or other bodily part) in the event that the window control is being accidentally pressed.
They will get warm to the touch if you are demanding too much current (too much torque) in your design.
Mike Betts
As easy as 355/113...
Unread 21-02-2007, 14:01
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
If the motors are heating up they are drawing current.
Make sure you have them wired correctly under control of the RC.
I would venture a guess that you have a programming / control issue.
Check the trim on the joystick if you are using that to control it.
If all else fails blame the programmers that's what we do
Mike Martus
Unread 21-02-2007, 14:04
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
If all else fails (checking the wiring and programming that is) you can mount one of the fans that came in the KOP to blow on the motor to help cool it.
Unread 21-02-2007, 14:18
In all liklelyhood you have them wired to run against each other and you have not calibrated the speed controllers that feed them. Under this condition, one or both (if both are hot) are trying to move because of the mis-calibration but are being held by the opposing motor.
I hope that they are not connected directly to the battery or the output of the main breaker as this is not allowed under the robot rules.
James, you can use a "Y" if you reverse the output wiring of one of the speed controllers.
The best way to check operation is to remove the coupling so that each motor can run independently, then power up the robot. You should see an effect immediately and I am guessing they will run in opposite directions and speeds. Reverse the wires to the motor that is running backward when you push on the joystick, then check calibration so that don't move when the power is on but the joystick is not pushed. When all of this is working, then check operation to see that they are running at about the same speed. If all of this is OK then install the coupling and check operation again.
help me plz RDD Programming 6 14-02-2007 13:25
Tether heating up! Shu Song Electrical 10 03-02-2005 01:14
i need specs for motors and pumps in the kit from last years competition plz help SCYTE16 Motors 3 18-11-2004 22:54
IR Beacons Heating Up Tripleoone Electrical 2 30-01-2004 22:43
