Go to Post FIRST is a community unlike the public at large, with the distinction lying on its gracious professionalism. I have no doubt that the community will continue to uphold and cherish this unique characteristic through difficult events such as this. - Joon Park [more]
Unread 21-02-2007, 11:22
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: The 8.2 (or 8.3) Battery Voltage Bug
Originally Posted by Joe Ross View Post
I did more testing today. I was able to reproduce it with all 2007 components.
Obviously, we can't test with 2007 components. I've been concerned with this, so I've been testing, both with my 2006 RC and this years 2007 RC before we shipped.
Our code has 8 ADC channels running Kevin's ADC code at 800 Hz and 16 samples per update (so that we could get 12 bit precision although in testing I think we can work just fine with the default 200 Hz and 4 samples per update), as well as three shaft encoders all running at up to around 1000-2000 pulses/sec. We also generate a *lot* of debug printfs, but the student programmers will probably comment out most of those in the pits. We've got Kevin's serial drivers in there as well, but no camera. I haven't been able to duplicate anything yet with either controller using the fixed library and linker scripts. The 2007 rc has the beta update for the master controller code, but the 2006 rc is un-updated.
I'll try to recreate your setup and torture-test my 2006 RC if I have a chance.
We're using a modified version of Kevin's ADC code at 3200hz.
Why that fast, if you don't mind my asking? And what did you modify?
I still wonder in the back of my mind whether protecting gpr15 doesn't fix the root cause, but only the most common symptom.
I'm pretty sure this just cures one symptom.
Reading battery voltage in software RbtGal1351 Programming 17 21-10-2007 13:07
How to obtain battery voltage from within EasyC DavidSJohnson Programming 2 14-02-2006 00:05
battery voltage compensation Rickertsen2 Programming 5 17-10-2005 22:12
RC Circuits Melissa Nute Math and Science 3 25-01-2004 05:02
Battery Chargers Neal Probert Electrical 46 16-02-2003 22:31
