Go to Post It will mean far more than you can imagine...and really, you can't lose. - David Kelso [more]
Unread 21-02-2007, 11:50
Martino's Avatar
Martino Martino is offline
FRC #1825
Martino is on a distinguished road
Send a message via AIM to Martino Send a message via MSN to Martino
pic: 1825
Unread 21-02-2007, 11:56
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: pic: 1825
Looks like a lot of weight high and on the back. what's the weight and height?
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 21-02-2007, 12:00
Martino's Avatar
FRC #1825
Re: pic: 1825
He is only 80lbs, and it is about 5'5".
Unread 21-02-2007, 12:04
lancerbotics's Avatar
lancerbotics lancerbotics is offline
FRC #2250 (Lancerbotics)
lancerbotics is an unknown quantity at this point
Re: pic: 1825
Looks like this might be top heavy when you deploy the arm.
Unread 21-02-2007, 12:19
WesleyC WesleyC is offline
FRC #1825
WesleyC is on a distinguished road
Re: pic: 1825
A few of Chuck's features:
Physical:
2 CIM motors powering high-traction wheels via chain/sprocket system
Shielded electronics case
Highly mobile and fast
3/4 of the robot's total weight centered over drive wheels, providing unparalleled traction for our weight
Incredibly light, coming in at 90 pounds including battery, 77 without!
I-frame arm construction prevents bending and twisting
Electrical/programmed:
Effective autonomous mode
Shielded wiring and programming redundancy protects against sensor damage
Programmed in such a way that it will refuse to break itself
Incredibly simple to drive
State programming enables robot's arm and wrist to return to a given position if bumped
Code has the ability to "learn" what the robot's current state is and some possible deficiencies, then work around them
Now for a few quick anecdotes...
Our arm, one might say, looks very heavy. Extremely heavy. Heavy enough that one wonders how that tiny fisher-price motor manages to lift it. However, it isn't so.
The arm is constructed out of a fiberglass/foamboard combination material that is extremely durable and strong, but very light. The whole arm weighs less than 5 pounds, and with the wrist and claw added it's still less than 7 pounds.
Some of our mentors were... shall we say, rather skeptical about a material this light. "How will it hold up under pressure?" they asked. "Won't it break off as soon as we try to use it?"
After an unfortunate incident involving a badly damaged ceiling fan (11-12 feet up, I might add--this robot will certainly be capable of scoring ringers on the high goal!) set to high speed, a completely undamaged arm and claw, and a team mentor spending several hours attempting to bend the brass fittings of his fan back into shape, the murmers stopped.
Our team members also were rather reassured after the robot slammed its arm into our rack at near full speed during the early stages of driving practice, shifting the full-size rack but not even putting a nick in the arm.
The robot is certainly back-heavy, however to date due to the control algorithms and other factors we have been pretty much unsuccessful tipping it unless we were absolutely trying to tip it. Also, all the major weight pieces (battery, drive motors, major structural elements) are fairly low, giving us a low COG. This also gives us enough traction to climb ramps easily.
Unread 21-02-2007, 12:35
waiakea2024's Avatar
waiakea2024 waiakea2024 is offline
ZOMGWTHKTHXBAIBBQ!!!!
FRC #1056 (Kekoa o Haaheo)
waiakea2024 is a jewel in the roughwaiakea2024 is a jewel in the roughwaiakea2024 is a jewel in the rough
Re: pic: 1825
Nice green. is that your arm?
Unread 21-02-2007, 12:38
Martino's Avatar
FRC #1825
Re: pic: 1825
Yes it is.
Unread 21-02-2007, 12:39
waiakea11's Avatar
waiakea11 waiakea11 is offline
FRC #1056
waiakea11 is on a distinguished road
Re: pic: 1825
HOWLY thats a huge green arm wow it looks.....big
Unread 21-02-2007, 16:06
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: pic: 1825
was there a reason for how thick you arm is? I understand its light, but did it need to be so thick for lets say support??
Unread 21-02-2007, 16:34
Martino's Avatar
FRC #1825
Re: pic: 1825
It is only 1" thick.
Unread 21-02-2007, 16:41
FRC #1825
Re: pic: 1825
For one, small quantities of this material are rather difficult to produce. For another, the larger the quantity of material, the more stable it is. We decided fairly early on an I-shaped beam for this design of an arm, and the fiberglass/foamboard material fit the bill perfectly. The thickness of the arm's pieces is in this case dictated by the width of the foamboard "core" of the material, the width of the pieces were chosen by the material necessary to withstand certain forces and the necessity of embedding plywood in certain points to prevent screws pulling through the material, and finally the width of the arm assembly was chosen as being excellent for:
1. Mounting our wrist and claw inside, leaving joints less exposed to being hit
2. Running a cable/chain link between a motor on the back frame and the wrist
3. Running all wires, cables, and the claw control rope down the center of the I structure
All that said, it also looks cool.
Unread 21-02-2007, 18:42
Rick-906's Avatar
Rick-906 Rick-906 is offline
inventor of the hoverbot-2006
AKA: Richard
FRC #0296 (Loyola Northern Knights)
Team Role: Communications
Rick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to behold
Re: pic: 1825
ahah we were thinking about nicknaming our robot chuck
its probably just gonna be the nothern knight
The knack of flying is learning how to throw yourself at the ground and miss.
--Hitchhikers Guide to the Galaxy
2006 Archimedes Divisional Champions
2006 Championship Winner
Unread 21-02-2007, 19:39
Bob's Avatar
Bob Bob is offline
AKA: Robert Kennedy
FRC #0084 (Chuck 84)
Bob is an unknown quantity at this point
Send a message via AIM to Bob Send a message via Yahoo to Bob
Smile Re: pic: 1825
[quote=WesleyC;583301]A few of Chuck's features:
Our robots name is chuck. I did not know there was another one named chuck. That is Awesome. Where did you guys get that name?
Unread 22-02-2007, 09:40
kcducttaper's Avatar
kcducttaper kcducttaper is offline
FRC #1825
kcducttaper is an unknown quantity at this point
Re: pic: 1825
I'm not sure really. I started calling him Chuck because.........I don't remember. I guess it just stuck.
