Go to Post Whatever the rule, MAKE IT CLEAR. - Bill Beatty [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 19-02-2007, 21:41
DustinB_3 DustinB_3 is offline
FRC #0935 (Railerobotics)
DustinB_3 is an unknown quantity at this point
Kansas City Regional
I was wondering how many teams that are going to the Kansas City regional got the camera to work and can use it to score a keeper in autonomous?
Unread 20-02-2007, 15:58
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
Smile Re: Kansas City Regional
Calling all Kansas City Teams!!!
www.team935.info
Unread 21-02-2007, 14:16
Birdman2388's Avatar
Birdman2388 Birdman2388 is offline
Glorious Leader
AKA: Trey Thomasson
FRC #1804 (Northmen Robotics)
Birdman2388 is on a distinguished road
Northmen Robotics at Oak Park will be there. Because of the bad weather this year, we were not able to get the camera working. We plan on using most of our pit time to get the camera working.
All you have to do is build momentum. If you need the right tools then invent them. - DDR "Drop the Bomb"
Yeah, I build robots. Big whoop. Wanna fight about it?
Unread 21-02-2007, 14:36
Martino's Avatar
Martino Martino is offline
FRC #1825
Martino is on a distinguished road
Send a message via AIM to Martino Send a message via MSN to Martino
I will be there with team 1825, We have the camera on our robot and we will use it in autonomous to score a keeper. You can see our robot here.
Unread 21-02-2007, 14:52
WesleyC WesleyC is offline
FRC #1825
WesleyC is on a distinguished road
I'm the programmer for 1825--if you have questions on getting the CMU cam working, I might be able to help.
The weather around here has been truly horrible! Especially for us, as a homeschool team--we are forced to drive from all over the place, some members traveling as much as 45 minutes one-way to get to a meeting.
However, yes, we did get our camera working. The lens is off-center, the default pan/tilt values were useless, and some of the numbers needed tweaked--but after a lot of effort we did eventually get it working quite nicely. However, our testing platform didn't allow for us to test very thoroughly with multiple lights being in view--I have a tweak in mind for when we get there, but I can't do too much with it until we actually get to a real arena.
Unread 21-02-2007, 14:59
I have actually gotten the camera to track just fine. I am just having problems using our gyro to turn to the angle of the light. The angle is so minute that the robot either doesn't move or it undershoots. If you have any advice please do tell.
Dustin
Unread 21-02-2007, 15:03
FRC #1825
The key here is to use a PD/PID loop in combination with the PAN_SERVO value provided by the camera's tracking code. Set the gain large enough, and even small differences in the camera's left/right position will cause your robot to move.
Unread 21-02-2007, 15:18
I have set the gain to 500 and the robot sits there and you can here the motors trying to move the robot. So I set the I higher but then it overshoots. Since it's in a case statement I am thinking I need more or less of a range for it to go to the next case. I have been working with it for 3 days straight but it still wont go to the correct angle.
Unread 21-02-2007, 15:47
FRC #1825
Why use a case statement in a PD loop?
The gain I used on our robot is 5 or 6... however, the output of the PD loop is then sent to our drive code, which incorporates an exponential drive algorithm.
The best thing to do is to use a printf statement right before the drive motors (or, even better, AFTER) are set--this will enable you to read EXACTLY what the drive motors are getting.
Since this may not be possible with the robots having been already shipped, I'll give you a quick fix:
By now, since you've probably figured out a minimum value that DOES make the motors move the robot, set a MINIMUM speed limit. Something like...
//150 and 105 are just arbitrary numbers; replace them with the minimum speeds that turns your robot
//copy this code for each motor
if (motor_speed > 129 && motor_speed < 150)
motor_speed = 150;
else if (motor_speed < 126 && motor_speed > 105)
motor_speed = 105;
Do that for both motors, and it should limit their minimum speed. If they're getting a value a little off center it'll increase their speed to the value you define as a minimum. That stops them from "humming" and actually makes the robot move, even at very low speeds as defined by the PD control.
Unread 21-02-2007, 17:01
I'll try that. Good luck it Kansas City.
Unread 21-02-2007, 17:34
FRC #1825
Hope that works for you!
Good luck, and we'll see you in March.
Unread 08-03-2007, 13:34
Happy Birthday! kawelch kawelch is offline
Formerly of 1653
FRC #1984
kawelch is a splendid one to beholdkawelch is a splendid one to beholdkawelch is a splendid one to beholdkawelch is a splendid one to beholdkawelch is a splendid one to beholdkawelch is a splendid one to beholdkawelch is a splendid one to behold
One week to Kansas City's Inaugural Regional. Good luck to all the teams attending. Let's make it a GREAT one.
Unread 14-03-2007, 18:27
Barry Bonzack's Avatar
Barry Bonzack Barry Bonzack is offline
Impossible to rain on my parade.
FRC #1902 (Exploding Bacon)
Barry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond repute
Send a message via AIM to Barry Bonzack
Looking for a webcast so the community of team 2165 can watch the team during their first regional. Does anyone know of the URL where I can find this?
Chair of Florida FIRST Alumni
Orlando Regional Planning Committee
FIRST Tech Challenge Florida Leadership Team
Program Planner on the Orion Spacecraft at the Kennedy Space Center
Twitter: @FL_FIRST_Alumni
Events I'm Emceeing/Game Announcing:
1/10/2015 FTC Jacksonville League Championship
1/11/2015 FTC Central FL Tesla League Championship
1/17/2015 FTC South Florida League Championship
1/24/2015 FTC Tampa/St. Pete League Championship
2/7/2015 FLL Orlando Regional
2/14/2015 FTC State Championship
2/26-2/28/15 FRC South Florida Regional
3/8/2015 FLL State Championship
3/12-3/14/15 FRC Orlando Regional
4/22-4/25/15 FIRST World Championship Event - FTC Franklin Field
Unread 14-03-2007, 20:56
The URL is:
http://www.more.net/services/videost...trobotics.html
Unread 15-03-2007, 13:55
Sugar_Bunny Sugar_Bunny is offline
AKA: Jackie
FRC #0016 ( Bomb Squad)
Sugar_Bunny is on a distinguished road
How are things shaping up?
Kansas City Regional Choi9111 Chit-Chat 2 09-01-2007 22:59
New York City Regional DanDon Regional Competitions 3 13-05-2006 22:58
New Regionals Kansas City? T967 Rumor Mill 28 18-06-2004 06:42
New York City regional archiver 2001 0 24-06-2002 02:32
New York City Regional archiver 2001 2 24-06-2002 02:25
