Go to Post I am mentored by individuals younger than 18 all the time. - Taylor [more]
Unread 21-02-2007, 09:34
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
pic: 696 Circuit Breakers - Wings Deployed
Unread 21-02-2007, 09:35
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Re: pic: 696 Circuit Breakers - Wings Deployed
Once the robot is disabled, how long do the ramps stay up? I'm concerned with the ramps falling below the 12" mark before they are counted due to the loss of air pressure. However, i'm sure you have found a way to counter the effects of gravity.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 21-02-2007, 10:52
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
if you use the double-action solenoids, your cylinders still have pressure after the robot is turned off. Assuming there aren't leaks, it should stay up for long enough.
Unread 21-02-2007, 10:56
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
How long does it take to get to full height?
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 21-02-2007, 12:54
The platforms stay up just fine. The time to lift depends on a lot of things. For one robot it could be as little as 3 seconds. For two simultaneously (which I imagine will rarely happen), it could be as much as about 7 seconds. There are 4 accumulators and a compressor onboard.
Unread 21-02-2007, 12:57
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
It looks heavy how much does it weigh? I like the arm and the gripper
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 21-02-2007, 15:48
in between teams
AKA: Luke Van Oort
What happened to the pickup wheel?
Team 1219: 2009 - Mentor
Unread 21-02-2007, 16:10
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Looks good. What's the spacing like between the outboard pistons and the chassis..and how tall of a vertical step is it to get onto the platforms? Steps that small ought to be no trouble for most robots to climb.
--Madison--
...down at the Ozdust!
Unread 21-02-2007, 17:53
hayakuneko's Avatar
hayakuneko hayakuneko is offline
AKA: Joshua
hayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of light
Send a message via AIM to hayakuneko
the robot weighs about 118 lbs.
the wheel was actually one of the designs that we considered, but in real life it just didn't work out as well as we hoped it would in our heads.
2007 San Diego Regional Winners (w/ 330 & 835/1216)
2007 Los Angeles Regional Finalists (w/ 980 & 580)
Unread 22-02-2007, 13:58
Steve Compton Steve Compton is offline
Project Manager, Mentor
FRC #1391
Steve Compton is a splendid one to beholdSteve Compton is a splendid one to beholdSteve Compton is a splendid one to beholdSteve Compton is a splendid one to beholdSteve Compton is a splendid one to beholdSteve Compton is a splendid one to behold
Hey all,
Fantastic machine! Can't get platforms any lower to the ground than that! Tell me... how do you deploy them - what is the mechanism that you lower them by? It looks very under control but I can;t decipher how you do it.
Thanks!
Unread 22-02-2007, 14:18
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
I noticed that this year you didn't use Colson wheels like previous years. Any reason why?
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 22-02-2007, 14:23
Originally Posted by Steve Compton View Post
Hey all,
Thanks!
I'm glad you ask. The platforms end up about 1.5" off the ground, in the lowered position. The philosophy here is that getting up a ramp may be a bit sketchy, and not all robots will be able to. So, we tried to make it easy. With the couple extra pounds we have to spare, we are looking into adding small leader ramps for the small percentage of robots that can't get over a 1.5" step.
I take it you've seen the YouTube video of the deploy? It is quite ingenious how they are deployed actually. The wings are held in by small aircraft cables, placed on hooks near the arm joint. There are springs that push the wings outward to give them the initial "kick" to start the fall. When the arm is raised all the way back over itself, it pushes the cables off the hooks, the springs push the wings past vertical, and they fall right to the ground. And it appears that air resistance slows them a little. When the cables release from their hooks, surgical tubing is used to retract the cables and take up all the slack, so we don't have dangling cables anywhere. There is a pot and a software lockout on the arm so it cannot go to the point of wing deploy until it is told to do so.
We never had a problem with colson wheels last year. But, we looked at the situation like this. We needed something light and narrow. We had a CNC available to use. We would have had to machine out and machine hubs for the colsons. So, why not just machine our own wheels? I'm glad we did. They are <0.5 lbs ea with tread.
And here's a quite comical video taken before we fixed the software.
Unread 22-02-2007, 15:06
FRC #1391
so you're saying that once past the vertical the wings fall by gravity? how does the outboard cylinder handle the impact?
Unread 22-02-2007, 20:01
The cylinder rod does not hit the ground if that is what you are asking.
Unread 22-02-2007, 20:34
DonRotolo's Avatar
Back to humble
FRC #0832
At least an alliance partner that accidentally hits one of the cylinders cannot say "I didn't see it!".
Very slick design, I think you'll do well with it.
Don
pic: 696 Circuit Breakers Complete! sanddrag Robot Showcase 7 16-03-2005 10:38
pic: o5' robot from team 696 circuit breakers! xKLzKobE08x Robot Showcase 2 22-02-2005 13:11
pic: 696 Circuit Breakers Teaser #2 sanddrag Robot Showcase 3 11-02-2005 05:30
pic: 476 - wings deployed CD47-Bot Robot Showcase 8 02-04-2003 23:37
Circuit breakers archiver 2000 8 23-06-2002 23:30
