Go to Post ... Proof that the Unsung FIRST Heroes paves the way! - Joe Matt [more]
Unread 21-02-2007, 23:28
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Problems turning
Well we shipped the robot with 2 main problems, we are 5 lbs over weight, and the robot doesn't turn.
im working on a sollution to the weight problem, but i have a question about the turning problem.
if you watch this video:
http://video.google.ca/videoplay?doc...15467259458065
you can see that we have issues with turning, we have to take a run and then quickly reverse one side to get it to turn.
i was thinking as a simple and easy sollution would be to replace all 4 wheels with the omni wheels available from andymark. as well as premounting the wheels to aluminum sprockets from ifi robotics so that its a simple swap at the competition.
my questions are as follows:
will this help us turn?
what are the disadvantages?
how much weight can we expect to loose by swaping to the aluminum sprockets?
Thanks alot.
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Turning 18... Astronouth7303 Chit-Chat 16 22-05-2006 09:29
Turning problems in Vex autonomous. jamesgecko Programming 3 09-03-2006 16:41
Turning problems, we need suggestions PLZ Oumonkey Technical Discussion 44 20-07-2005 12:21
Turning Trouble! Cadetdan General Forum 18 05-03-2005 08:55
Arm Turning (programming) Joelster Programming 4 13-02-2002 21:35
