Okay, well I have been wondering for some time now about the IFI> loader prompt that is seen during various times from the Controller.
It seems like the prompt is used in conjunction with the IFI loader app in some way, but I am not sure. It is also appearing when I do not have an OI connected. A second part of this question is: How do I use a controller without an OI? Apparently this is impossible, but since the entire code is open to change, couldn't it be modified to just simply allow the program port access (so I can test if my terminal program is actually working or not). Simply: How do I use the IFI> prompt and what can I tell it? and How would I go about enableing program port access (only?) even if the controller is not connected to the OI? I discovered that I had everything I needed for development but the OI (even had the joystick!). If there is nothing I can do, I would still like some info on IFI>Thanks! ![]() |
Re: IFI> Prompt
I have seen that thread, and posted on it as well.
Don't you need an OI to set the team number? ![]() I just want info on what the IFI> prompt and how to utilize it. |
| IFI sprockets... | brennerator | Technical Discussion | 1 | 14-01-2007 15:06 |
| Which Prompt are you using? | 114Klutz | 3D Animation and Competition | 0 | 10-01-2007 19:32 |
| Autodesk Visualization Prompt | RubyHawk | 3D Animation and Competition | 6 | 07-01-2007 16:48 |
| IFI> ? | Wynlyndd | Programming | 4 | 01-02-2006 21:17 |
| Chairmans Award Prompt | charanznable | Chairman's Award | 3 | 24-01-2006 20:40 |
