Go to Post FIRST is not the end...it is the beginning - Greg Needel [more]
Unread 21-02-2007, 23:55
htwiz2002's Avatar
htwiz2002 htwiz2002 is offline
Htwizard
AKA: Anthony Takata Bawahawba
#1290
htwiz2002 will become famous soon enough
Question IFI> Prompt
Okay, well I have been wondering for some time now about the IFI> loader prompt that is seen during various times from the Controller.
It seems like the prompt is used in conjunction with the IFI loader app in some way, but I am not sure. It is also appearing when I do not have an OI connected.
A second part of this question is: How do I use a controller without an OI? Apparently this is impossible, but since the entire code is open to change, couldn't it be modified to just simply allow the program port access (so I can test if my terminal program is actually working or not).
Simply: How do I use the IFI> prompt and what can I tell it? and How would I go about enableing program port access (only?) even if the controller is not connected to the OI? I discovered that I had everything I needed for development but the OI (even had the joystick!). If there is nothing I can do, I would still like some info on IFI>
Thanks!
TsAuKpAeTrA (Anthony)
Unread 22-02-2007, 00:17
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: IFI> Prompt
  1. See http://www.chiefdelphi.com/forums/showthread.php?t=42436
  2. Set your team # to 0
Unread 22-02-2007, 11:47
htwiz2002's Avatar
Htwizard
#1290
Talking Re: IFI> Prompt
I have seen that thread, and posted on it as well.
Don't you need an OI to set the team number?
I just want info on what the IFI> prompt and how to utilize it.
Unread 22-02-2007, 12:32
Re: IFI> Prompt
Search the forums for "programming protocol". There's a thread with pointers to what I think you want here (see especially posts #35 and #41).
IFI sprockets... brennerator Technical Discussion 1 14-01-2007 15:06
Which Prompt are you using? 114Klutz 3D Animation and Competition 0 10-01-2007 19:32
Autodesk Visualization Prompt RubyHawk 3D Animation and Competition 6 07-01-2007 16:48
IFI> ? Wynlyndd Programming 4 01-02-2006 21:17
Chairmans Award Prompt charanznable Chairman's Award 3 24-01-2006 20:40
