Go to Post FIRST: there is no second. - BandChick [more]
Unread 22-02-2007, 08:13
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Problems turning
Originally Posted by Cody Carey View Post
Since surface area has no bearing on friction, I would assume that this would be a bad Idea. By putting the two "sticky" wheels beside each other, you are reducing the amount that the wheel has to be pulled sideways when turning, and increasing the amount that it rolls along the turn. This decreases over all turning friction.
If you were to place them on opposite corners, it would do nothing to the amount that the sticky wheels have to be pulled sideways to follow the circle of your turning radius, and since One wheel has the same amount of friction as two, I wouldn't expect this to solve your problem at all.
From experience with vex bots, it definitely improves turning. Also look at 494/70 last year.
Omni placement all depends on how you want your robot to drive and how you want your robot to react to defense.
Turning 18... Astronouth7303 Chit-Chat 16 22-05-2006 09:29
Turning problems in Vex autonomous. jamesgecko Programming 3 09-03-2006 16:41
Turning problems, we need suggestions PLZ Oumonkey Technical Discussion 44 20-07-2005 12:21
Turning Trouble! Cadetdan General Forum 18 05-03-2005 08:55
Arm Turning (programming) Joelster Programming 4 13-02-2002 21:35
