Go to Post I just turned 51 and I'm still not sure what I want to be when I grow up! - Mike Betts [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 21-02-2007, 20:40
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
FP 9003 vs 9012 (was Attention Robot Inspectors:)
Apparently the FP service centers didn’t get that memo mentioned in Update #8”
Please note that the motor part number is 00968-9012, but the motor/gearbox assembly is 00968-2911. FisherPrice Service Centers have been notified that if a person identifies themselves as a FIRST participant, they can buy the motor and pinion and/ or gearbox they supplied for this years Competition. This will take effect on 2/2/07.
Nor do they fully understand that all 19-tooth FP motor/gearboxes are NOT created equal, not in the eyes of FIRST. They had me waste a 40-mile trip to one store by saying they had five, which turned out to be a mix of Mabuchi and 9003s. Another store could not locate any by part number, but realized they had four when I described how to identify the 9012, which brings me to the point of this post.
According to the guys at the service centers, some teams didn’t care if they had the right motor. Some even figured they could “get away with it” by swapping the sleeve with part number on it.
FYI: The 9012 has four cooling slots, which are slightly smaller than the two slots on all the others (Mabuchi – 9003) I’ve seen.
Unread 21-02-2007, 21:29
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Attention Robot Inspectors:
Some more information, for those who are interested:
The Mabuchi F-P motors (all illegal for 2007) are identifiable by the back end, because they lack the four ventilation holes on back end of the Johnsons (viz. Johnsons from the inside); the Mabuchi F-Ps look pretty much like the little Mabuchi motors, from the back, with distinctive curved slits. (Actually, according to Mabuchi's site, there's a new design for the RS-550 motor; compare the RS-545 to the new RS-550. The old-style RS-550s issued to FIRST teams should look like the RS-545 when viewed from the back.) Other differences between Mabuchis and Johnsons include the stick-on model label on a Mabuchi, vs. the painted numbers on a Johnson, or the "M" vs. "JE" logos. Inspectors can easily check for this, and catch obvious violations.
The Johnson 9012 looks the same as the 9003, and the same as the higher-powered Johnson F-Ps from 2002 and 2004. That unfortunately makes them indistinguishable at a glance, apart from the model number. (The pinion was different on the 2002 motor, but since the pinions are replaceable, it doesn't matter.) The 9003 lacks the internal thermal protection of the 9012, but is otherwise largely equivalent (though still illegal). The other motors are rated upwards of 200 W (mechanical power), and represent a competitive advantage over the approximately 170 W of the 9012, if substituted in violation of the rules.
Unread 21-02-2007, 21:48
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
So in the chaos that was the build season, none of us ever checked if we got the correct version of the FP in our KOP. Shame on us for assuming that we could use the parts provided in the KOP.
When we check these on Thursday of the Boston regional we will find out for sure. If we happen to have the wrong ones will FIRST have the correct ones on hand for us to use?
Also, does anyone know if the 9012 motor and the 9003 motor have the same size pinion? We had to modify the FP gearboxes and it would be much better for us if the motors could be switched into the same gearboxes (provided that we even have to switch).
Thanks,
RAZ
Unread 21-02-2007, 22:48
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Ok, so after going through a bunch of pictures from our build season, it is apparent that we were supplied with illegal FP motors in our kit. The link below shows what it looks like.
http://www.tomschindler.net/our_fp.jpg
It is very important that we find out if the pinion gear is the same on the 9012 and 9003 motors. If it is not, I need to find out how many teeth each has so I can be sure to have the appropriate parts to put the 9003 pinion on the 9012 motor. If anyone can help with this we will be eternally grateful.
Please share any info that you have.
Thanks,
RAZ
Unread 21-02-2007, 23:27
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Rob,
We were given the 9003's as well, but did not use the F-P motors on our robot at all. Therefore, we never asked for replacements from FIRST. Our 9003 motors are still untouched at the shop. I'll take a look next week and confirm what our pinion size is. If someone else has an unused 9012 to compare, we'll have our answer.
For information sake, I believe that most of the 9003's were given to teams that attended the Manchester, NH kickoff. (So, mostly New England teams had this problem...) The Manchester KOP's were packed last, as they didn't need to be sent in advance. These 9003's were leftovers from previous years, so they were probably inadvertantly mixed in at the time of KOP packaging.
Off to catch up on some sleep...
BEN
Unread 22-02-2007, 00:04
If they're the 9003s left over from last year, they have the 19 tooth pinion, like the current 9012. You can verify things without taking the assembly apart by looking for a raised "19" in two places on the black (or white) F-P gearbox case. Other versions will have a different pair of numbers. Be aware that it's just the 9003 motor that's illegal; the gearboxes are COTS items (from a F-P service centre), as are the pinions.
188's KOP 9012s and the identical spares were all equipped with the 19 tooth pinion, as were the 9003s from last year.
Unread 22-02-2007, 06:05
Retired
All ten of our 9003s have two cooling slots; all seven of our 9012s have four.
Some 9003s came with 16 tooth pinions, others came with 19 teeth.
Rob - the easier route to matching motor to transmission is to swap the drive gear in the transmission (the one that mates with the motor pinion). Irrespective of what Update #8 says, you will most likely have to buy the motor/gearbox combination; so you'll have the proper gear.
Unread 22-02-2007, 08:08
Electrical Engineer
Rookie Year: 1995
Jack, Ben, Rob, et al,
Have you informed FIRST of this issue?
Mike
Mike Betts
As easy as 355/113...
Unread 22-02-2007, 08:15
Bengineer
Mike, I "unofficially" informed FIRST. Meaning, I didn't go through the proper channels (re: email) to inform them. I also did not ask for replacements, as I knew that we weren't using those motors in our design this year. Other people have posted about their communication with FIRST on this subject, and it sounds like their issues were never resolved. Specifically, I know that BUZZ asked about the 9003's in the Q&A, and I don't think they ever received the replacement motors. (Jim Morin would obviously know better than I...)
BEN
Unread 22-02-2007, 08:42
Retired
Mike
N0 - it's not an issue for us any more. That may sound selfish, but there's not enough hours in the day to spend any telling them what they should already know.
Unread 22-02-2007, 08:55
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Hi Guys,
Thanks for the information and advice. We are contacting FIRST about this issue today, hopefully we can get some replacement motors. I think this could be an issue for many other teams. If Ben is right and New England teams got the wrong parts, then I am very concerned about the Boston event. There are alot of rookie teams who do not have a presence on these boards who might be in for a rotten surprise on Thursday.
On the positive side, at the beginning of the season I had some kids take apart one of the FP gearboxes to learn a bit about ratios, and I *seem* to recall the pinion having 19 teeth. If that is the case then this is an easy swap.
The only question I have on this is what is the performance difference between the motors? I am not worried about power because our system is overpowered anyway, but max speed is a concern. If there is a big difference in max rpm then we will have to change out some of our sprockets as well.
Thanks for the help,
RAZ
Unread 22-02-2007, 09:04
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Originally Posted by Ben Piecuch View Post
Rob,
I checked Team 95's, and ours are the 9003s. And we got them at Manchester.
We're not using them on the bot, however. (Unusual, we usually use them).
Unread 22-02-2007, 12:02
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Hi Guys,
After doing a bit of research on the 2 motors (9012 and 9003) and talking to FIRST, we are making much ado about nothing. The two motors are virtually identical and should be interchangeable. Recall that both were in the 2006 KOP with some teams getting one style and other teams getting other styles.
Looking at the 2006 tips and good practices document, the motors have almost the exact same performance.
Link to the document showing the motors are almost identical is below:
http://www2.usfirst.org/2006comp/oth...ices_Rev_D.pdf
I would strongly suggest that FIRST just allow both 9012 and 9003 motors and let this non-problem go away.
Either way, we had some 9012 motors shipped to us so we will be safe either way.
Best of luck to everyone,
RAZ
Unread 22-02-2007, 13:08
AKA: Dr. Brooks
no team (WRRF)
By definition, motors supplied by FIRST in the kit should be legal.
The notion that the 9012 and the 9003 are equivalent, however,
is a stretch. The 9012 has the internal current protection
and the 9003 does not. This difference is huge when a motor
is operated close to full power to lift a robot. We had to specifically
modify our robot lift to change the gearing to keep the internal current
limiter in the motor from popping midway through the lift, even
though the circuit breaker for the victor controlling the motor was
the 20 amp one.
The 9012 motor is easly obtained, although you might have to
sort through the parts that Fisher Price wants to sell you. If
the 9003 is declared legal we will happily swap the 9012 out
to ditch the internal current limiter.
Eugene
Hi Guys,
RAZ
Unread 22-02-2007, 13:16
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Excellent points Eugene, I hadn't thought about the current limiting feature (probably because our application operates well below stall torque and doesn't draw much current).
There are noticeable differences depending on your application, so maybe FIRST is justified in sticking with the 9012 motor. We are prepared to swap on Thursday of the Boston event.
Best of luck to everyone!
RAZ
the 20 amp one.
Eugene
Fisher Price Motor 9003 vs 9012 Mike Norton Motors 5 07-02-2007 19:27
So your original robot design was..... LightWaves1636 General Forum 23 05-02-2006 03:36
Other team inspectors uberchris General Forum 18 02-03-2003 11:24
Inspectors Jeff Waegelin Regional Competitions 5 28-02-2003 22:37
bribing the robot inspectors... archiver 2001 3 24-06-2002 00:11
