Go to Post The FIRST program is different. It has a different purpose. It isn't superficial, it's results are long term and lasting. I hope that FIRST is still on message. - JohnBoucher [more]
Unread 22-02-2007, 09:48
mentorDon's Avatar
mentorDon mentorDon is offline
FRC #1764
mentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these parts
Re: Let's see if you can help me... (Motors)
on our arm, we decreased voltage input to the motors when the arm moves down because gravity is doing the work. We also use pots to determine arm position to adjust the voltage depending upon arm angle.
Unread 22-02-2007, 10:04
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
that sounds like a coding problem to me. Since the window motors have worm gears, they should have anti-backdrive, i.e. they should never just fall when you are going down. You should be able to program the arm to go to a certain height and stay there without stalling the motors or anything.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 23-02-2007, 07:42
Justin,
You would think that the motors you have chosen would not back drive but in the configuration you are using them, once they are moving the arm weight will continue the motion. Even if you set the "brake" jumper on your victors, it might not help. Some of the suggestions above will help the situation, I am a big fan of surgical tubing but it might not be suitable for you design. Changing the ratio of the output shaft to arm might also help. I think a combination of a few ideas will solve your problem.
Unread 23-02-2007, 08:52
Cowmankoza's Avatar
Cowmankoza Cowmankoza is offline
KoZa
AKA: Matthew Koza
FRC #1251 (The Tech Tigers)
Team Role: Operator
Cowmankoza has a spectacular aura aboutCowmankoza has a spectacular aura about
Send a message via AIM to Cowmankoza
[quote=richardmcc2;584083]that sounds like a coding problem to me. Since the window motors have worm gears, they should have anti-backdrive, i.e. they should never just fall when you are going down. [quote]
contrary to popular belief, worm gears do backdrive, it just takes a lot more force to do so, and given that it is being used on an arm, it is very possible that it will backdrive
Team 1251 The Techtigers
2008 UCF Regional Champs thanks to 233 and 86
2008 UCF Regional GM Industrial Design Award
2007 Palmetto Regional finalists thanks to 1626 and 1758
2007 Palmetto Regional Motorola Quality Award
2007 UCF Regional Champs thanks to 1270 and 86
2007 UCF Regional GM Industrial Design Award
2006 Palmetto Regional Champs thanks to 11 and 247
2006 UCF Regional Semifinalist thanks to 86 and 710
2005 Palmetto Regional finalist thanks to 25 and 301
2005 Palmetto Regional Xerox Creativity Award
2005 UCF Regional finalists thanks to 845 and 1270
2005 UCF Regional Judges Award
2004 UCF Regional Rookie All-star Award (The real winner)
Offseason Development - Let's see it! sanddrag Technical Discussion 11 09-07-2005 01:23
LET'S GO ARCHIMEDES< SEE YA THURSDAY archiver 2001 0 24-06-2002 03:14
can anybody help me regarding motors? archiver 2001 9 23-06-2002 23:00
Can you find all eleven motors? archiver 2000 1 23-06-2002 22:01
Let's see Chairman's summaries! Andy Baker Chairman's Award 5 11-04-2002 12:32
