Go to Post Imagine a time before alliances. A time when secrecy was rampid and the Delphi Forum was just in it's baby stage. - Andy Grady [more]
Unread 22-02-2007, 10:32
jfish456 jfish456 is offline
FRC #0456
jfish456 is an unknown quantity at this point
Re: pic: Team 456
this is our 2007 robot. we have 8 wheel drive (andymark omni wheels in the front and back and ifi traction wheels in the center). our arm is capable of scoring on all 3 levels. we can lift 2 robots 12 inches
Unread 22-02-2007, 17:05
KingBK's Avatar
KingBK KingBK is offline
FRC #1279 (Cold Fusion)
KingBK is an unknown quantity at this point
Re: pic: Team 456
What are those ramps made of? plus how heavy is it?
Unread 22-02-2007, 18:50
FRC #0456
Re: pic: Team 456
they are from home depot. we were told it is a fiberglass composite but im not sure that is correct. it is very strong and realitively light. each platform weighs about 5.8 lbs and each lift wieghs about 13.5lbs
Unread 23-02-2007, 00:38
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: pic: Team 456
The surface material is Glasteel FRP (Fiberglass Reinforced Panel) wall panel from Home Depot. It is $30 per 4'x8' sheet. It is smooth on one side and "bumpy" on the other. It is used commercially as a wall board and made to be in wash down areas. We calculated it to be about 0.6 lbs per square foot. Not the lightest material in the world but it is fairly strong and was available locally cheap. It comes in white and we painted it red and blue to match our team colors.
pic: Team 456 (2) jfish456 Robot Showcase 6 22-02-2007 11:18
pic: Team RoboRaiders(75) and Team Mu Mu Psi(2016) versions 2007 Rohith Surampudi Robot Showcase 5 22-02-2007 08:43
pic: Team 456 pic 2 TEAM456MS Robot Showcase 9 03-04-2006 23:16
pic: Team 456 TEAM456MS Extra Discussion 1 01-03-2006 22:39
pic: Team 334 Team Members after the CeBit Convention CD47-Bot Extra Discussion 2 29-05-2004 14:14
