Go to Post "Defense wins qualifying rounds, offense wins championships." - Paul Copioli [more]
Unread 17-02-2007, 13:56
jhallel jhallel is offline
FRC #1943
jhallel is an unknown quantity at this point
help in assembly
i would like to know how can i export dimensions to the idw from parts that are assembled in the assembly doc
Unread 22-02-2007, 16:19
Mike Hvorecny's Avatar
Mike Hvorecny Mike Hvorecny is offline
3 Time Inventor Award Winner 05-07
AKA: Wire Master; Freespace21
FRC #0103 (Cybersonics)
Mike Hvorecny will become famous soon enough
Re: help in assembly
You should be able to just put dimensions in the .idw from the assembly. Change to your drawing annotations panel and use the general dimension tool. I could help you better if you were more specific.
Assembly code in C? red_alert_13 Programming 3 21-07-2005 15:01
Assembly? Astronouth7303 Programming 2 12-08-2004 11:30
Importing assembly into an assembly... James Green Inventor 8 22-01-2004 22:17
Assembly Code Venkatesh Programming 1 18-11-2003 17:39
Assembly?!? archiver 2000 2 23-06-2002 22:05
