Go to Post Or, to put it another way: It's a sport where you build your own athlete. - EricH [more]
Unread 22-02-2007, 18:00
in between teams
AKA: Luke Van Oort
pic: 587's 2007 robot, OCCAM VII: Deadline
Unread 22-02-2007, 18:01
CraigHickman
Posts: n/a
Re: pic: 587's 2007 robot, OCCAM VII: Deadline
Wow. Looks like a beast of an arm. How tall does the arm extend to? And did you have any issues with a high center of gravity?
Looks like quite a beast... I'm impressed.
JimHull's Avatar
JimHull JimHull is offline
FRC #1891
JimHull is an unknown quantity at this point
That looks heavy. What is the weight of your robot? Beautiful machine though.
Unread 22-02-2007, 18:26
in between teams
AKA: Luke Van Oort
Thanks, in the past we've had little luck with arms, so we're quite proud of this one. It extends to ~9 ft. The centre of gravity is not too bad, overall this robot is quite short (several inches under 4 ft), and most of the motors and the battery are mounted pretty low, plus we'll have bumpers mounted to further lower the COG and act as wheelie bars.
~115 lbs. The arm without motors is actually about 20-25 lbs, the reason it looks so much heavier is that it's made out of four pieces of aluminum angle and one square tube, and in this picture the angle has it's long side facing the camera. Thanks for the comment on its looks, but if you saw it from the other side, you'd probably think differently. 13 PWM cables from the arm/turret sensors + 4 from the camera + 1 for the pressure switch + 6 for Victors + 2 for spikes + 1 for the gyro in a tight amount of space leads to a really nasty looking electrical board. (We'll try to fix that at VCU, we don't want our insectors pulling out their hair trying to see what is going on in there)
Team 1219: 2009 - Mentor
Unread 22-02-2007, 18:34
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
What are you using that tape measure for? I ask because we were going to use it for a certain task also.
Mentor 2415
Unread 22-02-2007, 18:37
in between teams
AKA: Luke Van Oort
It has been modified to accept a potentiometer to measure lift height.
Unread 22-02-2007, 18:39
AKA: Sean
That is exactly what we were going to use it for.
Mentor 2415
Unread 22-02-2007, 18:40
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
Very nice. One question though:
Why bother making a turret that turns everything but the drivetrain when you can just ... turn the drivetrain?
Unread 22-02-2007, 19:00
in between teams
AKA: Luke Van Oort
The idea was that we would use a pair of cameras to aim the turret, drive near the rack, choose a height and press score. We couldn't squeeze the funds for a second camera, and didn't have enough debug time to make the vision come to fruition. (Actually, no debug time) We'll still try for autonomous scores with the camera, and maybe an ultrasonic sensor that we're thinking about mounting, but our operator control won't depend on it. A side benefit of the turret is that it makes it very easy to reach the floor since we can start with our arm stowed over the robot, then rotate into its playing position facing the front, so it only has to reach a very short distance to get to the floor.
PS: Can anyone identify all the 'bots this one pulls inspiration from. There are a total of 6 robots providing inspiration to at least one function, the most recent ones were from '05, the oldest from '01.
Unread 22-02-2007, 19:53
sporno's Avatar
sporno sporno is offline
AKA: David
FRC #0540 (Talon)
sporno will become famous soon enoughsporno will become famous soon enough
Send a message via AIM to sporno
OMFG THAT IS SICK!!!!!!!!!!!!!!...... IDK ABOUT YOU , BUT IM SEEING ANOTHER 5-5-5 THIS YEAR..... ( 540,510,587)
2005 NASA/VCU Quarter-finalist
2006 NASA/VCU regional-Semi-finalist
2006 FIRST Robot Rumble-Quarter-finalist
2006 FIRST Robot Rumble-Most Promosing Rookie Drive team.
2006 Championship-Curie
2007 NASA/VCU- Regional Winner
2007 Championship-Galileo
2007 FIRST Robot Rumble-Semi-finalist
80+ matches on the field
Unread 22-02-2007, 19:58
in between teams
AKA: Luke Van Oort
Thanks. Another 555 deal would be awesome, you guys are looking really, really good this year, and one can assume that 510 will have a nice robot. I guess we'll see in nine days eh?
Unread 22-02-2007, 20:51
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
What kind of transmissions are those?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 22-02-2007, 20:55
Sgraff_SRHS06's Avatar
Sgraff_SRHS06 Sgraff_SRHS06 is offline
Kappa != 1/(4Pi-Epsilon-Naut)
AKA: Steve Graff
FRC #1111 (The Power Hawks)
Sgraff_SRHS06 is a jewel in the roughSgraff_SRHS06 is a jewel in the roughSgraff_SRHS06 is a jewel in the roughSgraff_SRHS06 is a jewel in the rough
Send a message via AIM to Sgraff_SRHS06 Send a message via Yahoo to Sgraff_SRHS06
Are you sure you didn't steal this from Coach K's office containing secret plans to nuke Chapel Hill?
I'm loving the whole turret idea! Your robot is way too underrated! It's easily the most awesome bot I've seen so far.
POWERHAWKS FORUM
2006 Chesapeake Regional Semifinalists (Thank you 614 and 339!)
UM Class of 2010!!
Unread 22-02-2007, 21:22
in between teams
AKA: Luke Van Oort
AndyMark single speeds.
Steal? No, no no, we designed the delivery system for the device. Just kidding, Duke actually is one of our sponsors though...
Thanks! Although I think some of the robots that have been popping up on the Chief could eat us for breakfast...
Unread 22-02-2007, 21:55
AKA: Steve Graff
It's because all I've seen has been claws, claws, claws;;;;outside of the ThunderChickens and you and 1515. It's either your design or 1515's that could easily be a dominant robot.
POWERHAWKS FORUM
UM Class of 2010!!
**FIRST EMAIL**/2007 Program Book Deadline Approaching! Rich Wong FIRST E-Mail Blast Archive 1 03-12-2006 23:54
pic: Team 230 2006 Robot: Talon VII Sam Lipscomb Robot Showcase 14 28-02-2006 12:26
pic: 610 - Coyobot VII Jonathan Norris Robot Showcase 7 23-02-2006 00:13
pic: RhodeWarrior VII w/Two 2X CD47-Bot Robot Showcase 9 27-02-2004 13:16
pic: Rhode Warrior VII CD47-Bot Robot Showcase 5 24-02-2004 21:43
