Go to Post We figured it out. - benjiengi [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 05-02-2007, 16:20
1596guy 1596guy is offline
FRC #1596 (Sault Instigators)
1596guy will become famous soon enough1596guy will become famous soon enough
Exclamation Power Distribution Blocks, buying?
Due to some bad calls, the one of the yellow thingy's on our power distribution block got cut in half. Would anybody know where to buy/find a whole one?
Unread 05-02-2007, 16:52
dtengineering's Avatar
AKA: Jason Brett
Re: Power Distribution Blocks, buying?
While you are looking for the replacement "yellow thingy" (I don't know the official term either, but I know what you are talking about) you can continue to test your chassis by using a length of wire to connect the addidtional block to your existing blocks. I don't know if this is a tech-inspector approved fix, but so long as you use the appropriate gauge wire and have it should be safe.... assuming, of course, that you have enough free space on the distribution block for an additional couple of connection.
Perhaps you are doing this already... I just hate to see teams lose time while waiting for a part.
Jason
Unread 05-02-2007, 16:56
The part is made by Rockwell Automation and is PN 1492-CJJ12-4. You can find a local distributor at http://www.rockwellautomation.com/distributor. It was about 70 cents from our distributor.
This information and suppliers for most of the kit parts is in the "Tips and Good Practices" document available here: http://www.usfirst.org/WorkArea/link...id&ItemID=4054
Unread 05-02-2007, 17:06
Thanks, we just ordered some from Rockwell Automation, having no local suppliers.
dtengineering, thanks for the wire tip, we will use that till we recieve our order.
Unread 05-02-2007, 17:12
Were you able to order them in a quantity less then 20?
Unread 05-02-2007, 20:43
keericks's Avatar
keericks keericks is offline
AKA: Kent
FRC #1671 (Buchanan Bird Brains)
keericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of light
Has there been an "official" answer on cutting the yellow jumper down to allow only two red/black blocks to be used, rather than all 8 (since they are not being used?)
Unread 06-02-2007, 09:03
Nope, do you need a few?
Unread 06-02-2007, 13:34
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
I haven't seen anything, but it would be very nice if we could buy the 2-pole center jumper (that's what it's called, it's a "Screw Center Jumper, 12mm, 4-pole"). The 2-pole part number is: 1492-CJJ12-2 though it also has a minimum quantity of 20 limitation. If we could buy one of these (cutting the 4-pole doesn't sound like a good idea whatsoever) that would make us so very happy...
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 22-02-2007, 17:09
Dan Man's Avatar
Dan Man Dan Man is offline
Electro-Captian!
FRC #1566 (AmmoKnights)
Dan Man is on a distinguished road
Arrow Re: Power Distribution Blocks, buying?
TEAM 1566 STILL has extras--I've had them for a while. Let me know, and I'll send you one! (I cut before I should have, and had to order some!)
Bob
Unread 22-02-2007, 18:21
Jeremytice's Avatar
Jeremytice Jeremytice is offline
Addicted to FIRST!
FRC #1126 (SparX)
Jeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to all
Send a message via AIM to Jeremytice
Team 1126 would be very happy if anyone would be able to ship them a few jumpers. Just PM me if you are able to. Thanks everyone!
2006 SparX FLR champions with 229 and 1567 after being seeded 1st and Radio shack innovation in controls at FLR
2006 Galileo Division-DIVISION CHAMPION (thanks to 177 and 201)
2006 BattleCry great alliance 1519 and 195.
2006 RCCR hometown champs with 378 and 2567
2007 FLR Innovation in Contols award
2007 Buckeye General Motors Industrial Design Award
2007 Buckeye Finalist with 1038 and 1528
2007 Galileo quarterfinalists with 229 and 191
2008 FLR finalists with 378 and 1551
2008 Buckeye Champs with 1024, 1386, and 2048
2008 Buckeye Motorola Quality Award
2008 IRI Finalists with 1024 , 1625, and 1731
New Power Distribution jsmith234 Electrical 6 03-02-2007 15:05
Main Power Terminal Blocks? K.Porter Electrical 47 30-01-2007 21:15
buying 40 amp maxi fuse blocks Windward Electrical 3 26-01-2007 01:46
Power distribution Block? Pontchartrain Electrical 3 27-01-2006 07:30
Power Distribution xxmaddjxx Electrical 13 30-01-2005 00:43
