Re: A small issue with our Mecanums
Also it sounds like one side is outputing more power than the other.
Are you just setting PWMs or is there some feedback to control the speed? |
Currently, we are just using PWM's. I tried in the code to reduce power to several different permutations of wheels, and it made little or no change to the behavior of the system(it still pivoted on the rear wheels), I don't think the problem lies in wheel speed. But thank you for the suggestion.
If you can get some feedback happening you are going to be a lot happier with your handling, I think. We use shaft encoders to ensure the wheels are all turning at the correct speed to give us the motion we want, while I know of other teams who have reported success using the gyro to stabilize their heading.
If you've got the banebots encoders and divider cards on board, we've developed some code that might be able to help, which we are willing to share. Drop me a PM. If not, it is probably easier to just tack on a gyro... perhaps there is someone willing to share their techniques for gyro stabilization of a mecanum drive. To see some clips of how we move try http://www.youtube.com/watch?v=gyn9e0cT3-A Jason P.S. Some posts surrounding mecanum drives insist that you need a suspension to have a working mecanum drive system. While that may be true on a rough surface, we are quite satisfied with just having a bit of flex in the frame. |
#7
this may come too late to really help you, but by changing the wheels, you will have to flip your side-to-side controller, otherwise you will go right when you wanto to go left. all other driving functions (forwards, backwards, and spin) like regular tank drive, so it will ramain unaffected.
| Small Banebots Motor Issue - Lessened torque and smoke | sanddrag | Motors | 10 | 12-02-2007 21:41 |
| Issue with downloading code to the 2007 RC | thefro526 | Programming | 3 | 10-02-2007 17:26 |
| Issue with CMUCam2 Demo application | Bio | LabView and Data Acquisition | 12 | 21-01-2006 16:08 |
| Our Small Parts Experience, to all TEAMS | Anton Abaya | General Forum | 29 | 04-02-2002 15:52 |
