Go to Post I thought you guys were surposed to be nerds. - Funzo [more]
Unread 23-02-2007, 11:02
Billfred's Avatar
Billfred Billfred is offline
Balancing an arm that starts down?
Alright, so it's been recommended frequently that arms get some counterbalance going. It may be overkill for a CIM-powered arm, but we've got a few pounds to play with at Palmetto; I'd rather make it beneficial rather than just bolting junk onto the robot.
The one problem is that our particular arm (photo) has to start down in order to fit in the box. Seems like we could rig up some form of latch to pop the arm free during the autonomous period, but I'm sure there has to be some other means that I don't know about.
Are there any Thursday-at-the-regional tricks that've worked in the past?
Unread 23-02-2007, 11:17
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Balancing an arm that starts down?
If the arm pivot were more substantial, and you didn't need ballast, I'd recommend the surgical tubing tied to the back end of the arm trick....as has been mentioned by a few others in various threads....
Unread 23-02-2007, 11:56
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
I see you are using pneumatics. A fast, simple solution may be using a small piston as a brake against the lower motor/sprocket/chain?
Unread 23-02-2007, 12:11
BRosser314's Avatar
BRosser314 BRosser314 is offline
Post-A-Holic
AKA: Brandon Rosser
FRC #0469 (Las Guerrillas)
BRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to behold
Send a message via AIM to BRosser314 Send a message via Yahoo to BRosser314
use a spring loaded stopper to latch and hold the arm in place, and to push ur arm down in auto, just do a quick josle of ur robot.
Unread 23-02-2007, 12:21
Andrew Blair's Avatar
FRC #0306 (CRT)
If you use constant force springs, you can more easily tune the force to an extent so that it will basically stay in whatever position you choose to put it in. Or, in the same respect, though not as effective, you could tune any sort of regular spring balance so that it still assisted the arm, but would no have enough force to swing the arm out of place at start.
Search for constant force in Mcmaster.
If you just want a latch to hold the arm down at the beginning of the match, you could try a leaf spring pressed against the side of the arm. Any arm would be able to simply pull past it if you wanted to deploy.
-Sir Francis Bacon
-Albert Einstein
Unread 23-02-2007, 12:56
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
We use gas springs from McMaster.com to counterballance our arm (like the ones you find holding up a car hood or liftgate). They're light and not too pricy at ~$15. The most common are compression, so it makes them pretty easy to mount too.
Unread 23-02-2007, 13:03
AChastain's Avatar
AChastain AChastain is offline
FRC #0234 (Cyber Blue)
AChastain will become famous soon enoughAChastain will become famous soon enough
We found that a small bungee kept our arm pretty balanced. We had to make some modifications to make sure that it was not too tight. If you've ever been hit by a bungee, you can understand.
"Thirty bucks says the blue guy wins."
"You On!"
- bystanders, MEGAS XLR
Camera Shorts (and starts smoking) kokodabear Programming 7 20-02-2006 20:50
FLL registration starts today archiver 2001 0 24-06-2002 04:14
Is Balancing 2 Goals That Difficult???? archiver 2001 21 24-06-2002 02:12
A day that will go down in history! archiver 2000 4 24-06-2002 00:34
