Go to Post Using a mouse is so 20th century! - Tom Bottiglieri [more]
Unread 23-02-2007, 11:54
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: Blizzard VIII
Looks like a solid bot guys. Hopefully we'll get to play with you at LA
2001-2004: Team 100
2006-Present: Team 254
Unread 23-02-2007, 12:21
gabrielse's Avatar
gabrielse gabrielse is offline
FRC #1748 (Lab Rats)
gabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to behold
How do you deploy your ramps?
Unread 23-02-2007, 15:30
Vince lau's Avatar
Vince lau Vince lau is offline
Building robots since 1995
FRC #4914
Vince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond repute
Send a message via MSN to Vince lau
Looks like another great robot from team 188, good luck at your regionals and see you at GTR
2005 - GTR WFFA
2006 - Waterloo Regional Champions with 1114 and 1503
2010 - Waterloo Rookie inspiration and Highest Rookie Seed, #2 Alliance Captain, Semi-finalists.
2011 - Waterloo Finalist thanks 1310 and 610
2014 - imagery and rookie allstar award gtr west
2014 - rookie inspiration and winners with 188 and 610 north bay
Unread 23-02-2007, 16:09
J Flex 188's Avatar
J Flex 188 J Flex 188 is offline
"flock their sheep"
AKA: Jeffrey Li
FRC #2505 (The Electric Sheep) & FRC #0188 (Blizzard)
J Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond repute
Send a message via ICQ to J Flex 188 Send a message via AIM to J Flex 188
Airline cable connected to two pins which hold the ramps upright. The cable is linked to a window motor in the centre of the robot. Soon as we need to deploy the ramps, we just run the motor. Originally we tried with a servo but it ended up not being entirely reliable. I'm sure someone else can provide more detail! There are also turnbuckles to adjust tension.
Woburn Robotics, Class of 2005.
Unread 23-02-2007, 17:10
Back after 4 years off
FRC #5279
You guys in Canada sure are coming out with some impressive bots. Is it possible that 296 will be removing the only from the title "First and only FIRST champions from Canada"?
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 23-02-2007, 18:22
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
The ramps are deployed as J Flex stated. The leg supports have springs which help to push the ramp outward and then we let gravity do the rest. I believe I was told they deploy in about 2 seconds.
The robot in the picture is missing the cage over the center of the robot. We believe that if a narrow robot wants to drive over to the other side it will be able to.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 23-02-2007, 19:22
coolguybigt's Avatar
coolguybigt coolguybigt is offline
engineer rock (software is fun)
AKA: T
FRC #2043 (Robo Squad)
coolguybigt will become famous soon enoughcoolguybigt will become famous soon enough
Send a message via AIM to coolguybigt Send a message via MSN to coolguybigt
nice robot
i wondering is that robot over weight and how high is it
could ur arm put tube on all 3 spot
never give up,keep on going(thing will get better).
if you need help just ask? poeple are help to help. thank you
Unread 23-02-2007, 19:30
Nica F.'s Avatar
Nica F. Nica F. is offline
Mechanical Design Engineer
AKA: That silly panda girl from back in the day.
Nica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond repute
I'm very excited to see this robot (And team of course ) in Los Angeles in less than two weeks!
Good Luck to you guys, ILL BE CHEERING FOR YOU!
Product Designer, Mechanical Engineer
Purdue Aeronautical and Astronautical Engineer Graduate - Boiler up!
Team 22 Double Deuce / Team 4 Element Alumni / Former 1646 Precision Guessworks Mentor
Unread 23-02-2007, 20:01
Grow Up? Why?
Originally Posted by coolguybigt View Post
nice robot
The robot is not overweight according to our scales, however......
Yes we can place on all three levels.
Special thanks to team 25 for allowing us to modify their drive train design from last year. We believe that this has drastically improved our mobility system from last year.
Unread 23-02-2007, 20:07
Frinkahedron Frinkahedron is offline
Wants to go sledding
AKA: Mark Umansky
FRC #0612 (Chantilly Robotics)
Frinkahedron is on a distinguished road
Send a message via AIM to Frinkahedron
Unless the folded up ramps prevents so, hope you don't get a tube stuck on the camera mount, otherwise you're not allowed to pick up any more to play with until you get rid of it
Hokie Hokie Hokie Hi
Tech Tech VPI!
Unread 23-02-2007, 21:34
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
wow thanks for the shout out. We hope to impress you with our new drive train. Are you coming to nj this year? We Have a few new things to show.
shaun
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 24-02-2007, 07:45
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
Steve,
How much do the ramps wiegh?
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 24-02-2007, 12:30
Grow Up? Why?
Originally Posted by Tim Delles View Post
Steve,
How much do the ramps weigh?
I believe that they are about 40 lbs total. We want all teams to be assured that the ramps are solid, won't collapse, and wide enough to drive on. The widest ramp is 37 1/2 inches I believe so wide robots will have to be a bit careful. It shouldn't be to hard of a task as they are driving right in front of themselves.
Total ramp width, including robot, 12 ' 9".
Unread 25-02-2007, 00:50
Rick-906's Avatar
Rick-906 Rick-906 is offline
inventor of the hoverbot-2006
AKA: Richard
FRC #0296 (Loyola Northern Knights)
Team Role: Communications
Rick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to behold
no we'll be adding a "to win twice in a row" onto that
The knack of flying is learning how to throw yourself at the ground and miss.
--Hitchhikers Guide to the Galaxy
2006 Archimedes Divisional Champions
2006 Championship Winner
pic: 610 Coyobot VIII - Chassis View Jonathan Norris Robot Showcase 1 10-02-2007 17:18
pic: Blizzard Steve W Robot Showcase 22 08-03-2006 08:32
pic: Cyber Blue 234 - Falcon VIII David Kelly Robot Showcase 11 24-02-2006 11:13
pic: Cyber Blue 234 - Falcon VIII David Kelly Robot Showcase 2 23-02-2006 23:37
Blizzard Going Down? Raven_Writer Chit-Chat 3 03-07-2003 15:54
