Go to Post The mission of FIRST is not just to promote science and technology, but to help every student involved to reach their full potential and achieve their dreams - Mike Ciance [more]
Unread 23-02-2007, 12:07
gabrielse's Avatar
gabrielse gabrielse is offline
FRC #1748 (Lab Rats)
gabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to behold
Inverting a joystick axis in arcade mode
Is there any easy way to invert one joystick axis in arcade mode?
We just got a USB-Chicklet and a Logitech Dual Action Gamepad. Our code uses arcade mode and works perfectly with the joystick from the kit of parts. Unfortunately, the chicklet inverts the x-axis of the gamepad's joystick.
We do not want to change the direction the robot drives.
The only way I know how to work around this problem is to rewrite the arcade function (using the default MPLab 1-joystick drive code as a model). Our rookie programmer won't have time to do that.
Unread 23-02-2007, 12:35
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Inverting a joystick axis in arcade mode
Not quite. None of the modes for the Chicklet use the "aux" analog input for a real axis, they use them for encoding buttons. So, if no buttons are pressed p1_aux (or whatever port you're using) should be larger than 127 all the time if you are using the chicklet. So do a check for that, and if p1_aux is significantly greater than 127, switch the X axis.
I've considered something similar to make sure nothing goes weird if our chicklet is malfunctioning.
Not that unless you're in your fix-it window, you shouldn't be coding right now, however.
Unread 23-02-2007, 13:38
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
You can also invert all four motors and that should effectivly invert the axis.
Unread 23-02-2007, 13:46
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
You can do it in hardware by swapping the pwms on the robot. You may then need to reverse the Red & Black leads from the motor to the Victors.
Or in software just swap the Arcade PWMs for rightmotor/leftmotor. You may also need to check the 'Invert Direction' boxes.
Unread 05-03-2007, 10:16
gabrielse's Avatar
Our programmer switched the left and right motors in the Arcade block and solved the problem. Unfortunately, we have to reprogram if we want to use the KOP joystick. Thanks for all your help.
Inverting x-axis jkjohnson Control System 8 22-02-2007 02:24
Arcade Mode (12) does NOT work jakk Programming 2 10-07-2006 19:27
pwm outputs vs. joystick y-axis stephenthe1 Programming 4 01-12-2004 17:29
Inverting Y axis on joystick FormatteD_C Programming 7 24-02-2004 16:56
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
